Activity Forums DaVinci Resolve DaVinci Resolve 14 beta 7 released
  • DaVinci Resolve 14 beta 7 released
    Posted by Peter Chamberlain on August 16, 2017 at 4:16 am
    We are please to announce the availability of DaVinci Resolve 14 beta 7 on our support web site.
    https://www.blackmagicdesign.com/support/family/davinci-resolve-and-fusion
    This is a no charge update for all existing customers.
    Please backup your projects and database before updating and note the special items at the bottom of this notice.
    New items for beta 7
    Reorganized Project Settings, User Preferences and System Preferences
    Added support for speaker setup in System Preferences
    Added support for displaying track automation data on the Fairlight page
    Added support for rendering multiple individual audio tracks
    Improved Multicam playback performance
    Improved scrubbing and playback performance for compressed CinemaDNG clips
    Improved Fairlight timeline navigation and performance when zooming, scrolling and resizing tracks
    Improved Fairlight video playback performance
    Improved audio quality when scrubbing a clip in the source viewer
    Dual machine servers are no longer supported on Linux
    Added support for adding, deleting and modifying clip level keyframes on the Fairlight page
    Added support for track properties, AudioFX and automation in nested timeline and compound clips
    Added support for the Razor command in the Fairlight page
    Added support for cut, copy and paste actions in the context menu in the Fairlight page timeline
    Added support for displaying the composited preview in 2-Up and 4-Up modes when trimming
    Improved resizing behavior for tracks and buses in the mixer
    Improved viewer image quality when zooming in and out of the Color page viewer
    ResolveFX Color Stabilizer is now GPU accelerated
    ResolveFX Timelapse Deflicker is now GPU accelerated
    Improved playback performance for 4K AVC Intra clips
    Added support for decoding and encoding 32-bit float OpenEXR clips
    Added support for the Metadata inspector on the Fairlight page
    Added support for the Bus Assign and Bus Format dialogs in the Edit page
    Improvements to the timeline compare tool including a better zoom range and the ability to show Display Names
    Data Burn-In has been moved to the Workspace menu
    Added a new LMT Neon Suppression CLF
    Added support for viewing track layers in the Edit Index
    Addressed a crash when placing compound clip on the timeline using the Place On Top command
    Addressed an issue where large projects with compound clips would sometimes not playback sound
    Addressed an issue where audio meter bars would sometimes not clear when switching pages
    Addressed an issue with multicam playback where the embedded audio would be played instead of the linked audio
    Addressed an issue where syncing a multicam by sound would not work with custom channel mappings
    Addressed an issue where the Dip to Color Dissolve transition would revert to using default parameters after an AAF import
    Addressed an issue where the Fairlight video player would sometimes show black frames
    Addressed an issue where moving a track up/down would leave the Fairlight timeline out of sync
    Addressed an issue where clips in the Fairlight page would sometimes show waveforms from the wrong channel
    Addressed an issue where the automation of audio pan parameters would not work
    Addressed an issue where disabled audio plugins were still available for insertion in the Mixer plugin insertion menu
    Addressed an issue where trimming a clip in a layer would temporarily cause the clip to jump to the top most layer
    Addressed an issue where changing an audio track format would leave the track in an inconsistent state
    Addressed an issue where moving a clip to a track with a different format would not work correctly
    Addressed an issue where the Track Input dialog would not display the actual track name
    Addressed an issue with linear power window softness when a flip or a flop is applied on the clip
    Addressed an issue with the advanced stabilizer data getting reanalyzed when parameters were changed
    Addressed an issue where an offset would sometimes be created between a Power Window and the grade
    Addressed a crash when disabling a node when in Highlight Mode split screen
    Addressed a crash when creating a compound clip and switching to the Color page
    Addressed an issue where dragging certain clips or folders into the Media Pool from the file browser would not work
    Addressed an issue where selecting multiple bins in the Media Pool would make the folder view scroll to the top
    Addressed an issue with incorrect timecode on some Panasonic QuickTime clips
    Addressed a crash when reading some Panasonic MTS clips
    Addressed an issue where the first few frames of some MTS and H.264 clips would show as offline
    Addressed an issue with incorrect waveforms for some MTS clips on Mac
    Addressed an issue where thumbnails would not be shown for certain CinemaDNG clips on Windows
    Addressed an issue where the clip extents were displayed incorrectly for some variable frame-rate clips
    Addressed an issue with the audio playback of certain mp3 files
    Addressed an issue where some IMX MXF clips would not playback audio
    Addressed an issue with the option to render one channel per track
    Addressed an issue where the selected keyboard preset would sometimes get changed
    General stability and performance improvements
    Important information regarding dual-server configurations on Linux
    Starting from DaVinci Resolve 14 beta 7 the dual-server configurations are no longer supported. Please ensure that your system has been re-configured appropriately prior to upgrading to this version.
    The legacy “Configure DaVinci Resolve” application will no longer be supported. DaVinci Resolve Preferences can now be accessed from the DaVinci Resolve application menu similar to Mac and Windows.
    Important information regarding Preferences and Project Settings
    Starting from DaVinci Resolve 14 beta 7 the Preferences and Project Settings have been reorganized into Project Settings, System Preferences and User Preferences. Settings such as keyboard shortcuts and panel sensitivity controls are now stored locally on the machine instead of with the project.
    These settings (along with others) can now be found under the User tab in Preferences.
    There is also a new user guide available with this beta update.
    Marc Wielage replied 9 years, 1 month ago 2 Members · 1 Reply
  • Marc Wielage
    August 17, 2017 at 2:31 am
    Be sure to save your Resolve Keyboard Mapping shortcuts prior to installation, export them to a text file, and then import them once you have 14b7 up and running.
    Be warned that because b7 has moved some of the Project Settings to Preferences, you will need to redo your Auto Save, Live Save, and Panel Settings from scratch. This is mentioned in the ReadMe but is not yet in the August 2017 manual.
