Activity Forums DaVinci Resolve DaVinci Resolve 10.1.3 released
  • Laco Gaal
    March 20, 2014 at 1:38 pm
    what is a better setup currently for generating DNX36 dailies (quarter-res)? A RR-X, or a multi-GPU setup?
    thanks
  • Jonathon Lee
    March 20, 2014 at 2:44 pm
    Has anyone tried this on a Windows resolve or macs only so far?
  • Robert Ruffo
    March 20, 2014 at 9:55 pm
    Anyone take a close/careful look at quality differences (if any) between GPU and CPU debayer? WIth Rocket quality was much lower, and I am hoping there is no difference with GPU
  • Robert Ruffo
    March 20, 2014 at 11:50 pm
    Instant crahs with anything that has Red files in it.
    4GIG VRAM gtx 680 on Mac Pro 12 core – granted I tried it while a screen was hooked up to the compute card.
    Also gave me that weird “Red decoders not same number…” error
  • Prathvish Hegde
    March 22, 2014 at 6:48 am
    2 titans
    5k r3d full premium – 17fps
    5k r3d half – 17fps
    redrocket
    5k r3d half – 17fps
    while there isnt much difference between the redrocket and titan but i think resolve is not using the second titan for debayeringing r3d also half resolution and full resolution premium are playedback at the same speed 🙁 .
    anyways nice fitst step .
    setup specs:
    supermicro system with 2 titans(gpu),redrocket,decklink extreme 3d,hba,quadro 4000(gui),controlsurface and dolby prm4200,omnitek.
    prathvish hegde
    colorist
    (DaVinci Resolve and 2Kplus)
    https://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
  • Chris Kenny
    March 22, 2014 at 1:15 pm
    [prathvish hegde] “while there isnt much difference between the redrocket and titan but i think resolve is not using the second titan for debayeringing r3d also half resolution and full resolution premium are playedback at the same speed 🙁 “
    Seeing the same thing on a 12c/D700 Mac Pro — Half Res Premium with 5K Epic footage seems to be basically the same speed as full-res (similar speeds to what you’re seeing). I wonder what’s up there.
    Half Res Good is silky smooth now though, and full-res decodes are actually a little faster than what we got from the Rocket over Thunderbolt, so the Rocket is officially getting retired from our grading suite. I suppose it will still have its place for on-set transcoding (hooked up to a MacBook Pro). Although if buying a system for on-set transcoding today we’d probably just figure out how to pack up a Mac Pro now that it’s so tiny, and forget the Rocket.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • Rohit Gupta
    March 22, 2014 at 3:41 pm
    We’re getting 5K full-res in RT on the 12-core/d700.
  • Chris Kenny
    March 23, 2014 at 12:01 am
    [Rohit Gupta] “We’re getting 5K full-res in RT on the 12-core/d700.”
    Is that with full frame footage or is that 5K widescreen? Mine seems to settle down at ~18-20 fps with full res full frame 5K material. Same in ‘half res premium’ mode. (I copied a couple of clips to the internal SSD to rule our storage bottlenecks.)
  • Anish Prithviraj
    March 24, 2014 at 5:06 am
    Hi Prathvish/Chris,
    Please make sure that you disable “Use Red Rocket if available”. If that is enabled and a rocket is available, it is using the rocket instead of GPU (even if GPU for Red Debayer is enabled).
    Anish
  • Chris Kenny
    March 24, 2014 at 5:11 am
    [Anish Prithviraj] “Hi Prathvish/Chris,
    Please make sure that you disable “Use Red Rocket if available”. If that is enabled and a rocket is available, it is using the rocket instead of GPU (even if GPU for Red Debayer is enabled). “
    Unchecked here (and the Thunderbolt Rocket is disconnected). I’m curious if something might be wrong here and I should be seeing better performance.
Page 2 of 3
