Activity Forums DaVinci Resolve Davinci Resolve 10 Lite – export aaf/xml greyed out. Why?
  • Davinci Resolve 10 Lite – export aaf/xml greyed out. Why?
    Posted by Marcel Steuermann on November 24, 2013 at 9:31 pm
    Hi everyone,
    I just imported an xml-project using CineformHD avis into DV 10 Lite which worked just fine using the import under edit.
    I also rendered the files into avis which also worked fine.
    Now that I want to export the xml back into vegas I have to find out that “Export aaf/xml” is greyed out. What am I doing wrong? Also other files imported into DV10 Lite cannot imported as a aaf or xml project. For me the export worked fine using DV9 Lite in the past.
    Thanks for your help!
    Ryan Atkins replied 11 years, 1 month ago 4 Members · 5 Replies
  • Peter Chamberlain
    November 25, 2013 at 1:15 am
    It sounds like your timeline is not selected. Select the timeline in the top LHS timeline list and right click to select to export XML.
    I dont understand your second issue. Can you clarify?
    Peter
  • Marcel Steuermann
    November 25, 2013 at 1:52 pm
    Thanks Peter! Now I got it.
  • Kevin Fratz
    April 3, 2015 at 1:27 am
    Is there a button to highlight the entire timeline?
  • Kevin Fratz
    April 3, 2015 at 1:32 am
    Is there a button that highlights the entire timeline? When I shift/select all the clips, the “export aaf/xml” is still greyed out.
  • Ryan Atkins
    July 16, 2015 at 6:47 pm
    In DaVinci Lite 11, you have to select the “Edit” tab to export XML. However, do know that any color information will not transfer over if doing XML. You must export from the “Deliver” tab for color info to be added.
