Activity › Forums › DaVinci Resolve › DaVinci Performance Problem
  • DaVinci Performance Problem
    Posted by Chybu Meee on April 6, 2014 at 8:50 am
    Hi there,
    I’m facing some problems with the performance of DaVinci 10 on my PC. And i can’t figure out what’s the reason. When I simply playback a FullHD MOV in the color tab (with no changes aplayed) i can’t get to 25 fps realtime. It’s going only to 15-16 fps. With 2k Proress 444 from Alexa i get like 6-7 fps (no changes aplyed). I’m actually getting similar performance on my mbp 2012, which i think is wierd. I’ll appreciate any advice !
    My pc configuration:
    Intel Xeon Hexa Core C5650 – 6x 2,67 GHz
    RAM 12 GB 1333mhz
    nVidia Quadro FX 580
    SSD disk Kingston
    Decklink 4k extreme
    windows 8/7
    Chybu Meee replied 12 years, 5 months ago 2 Members · 4 Replies
  • Andi Winter
    April 7, 2014 at 8:50 pm
    get an additional gtx gpu, i think the quadro
    could be your bottleneck.
  • Chybu Meee
    April 8, 2014 at 6:41 am
    Thank you for your response. Ijust tryed different video card and i’m getting much better results. I think davinci can’t use the quadro and uses just 1/4 of it. Anyway I’m about to buy a new videocard but i’m a bit tight on a budget so i’m deciding between this two cards:
    https://www.newegg.com/Product/Product.aspx?Item=N82E16814125437
    https://www.amazon.com/MSI-DisplayPort-PCI-Express-N760-4GD5/dp/B00E4MQOE6
    The Gtx 760 got 1152 cuda and 4GB.
    The Gtx 680 got 1536 cuda but only 2GB.
    Which one do you think would work better for davinci ?
    Thanks again !
  • Andi Winter
    April 8, 2014 at 9:20 am
    if you wanna use noise reduction, go for more
    ram! as the announced v11 will have better caching
    as well this seems to be more future-proof!
  • Chybu Meee
    April 9, 2014 at 8:08 am
    I just got the GTX760 ! Thank you !
