Activity Forums DaVinci Resolve DaVinci not recognizing my edits
  • DaVinci not recognizing my edits
    Posted by Arturo Sinclair on January 9, 2015 at 5:45 pm
    Never had this problem before. I have an interview edited in PremierePro CC 2014, a 10 min program. The source material is a single 45 min .mov
    When importing the XML into DaVinci 11 the cuts are there, but they are either all the same moment or apparently random moments of the 45 min original movie, mostly from the beginning of the source. I even created subclips of every cut but the result is the same.
    Regardless of the clip it seems to ignore the timecode and goes back to the start of the source in every cut. Hope this is clear, any ideas anyone? don’t know what else to try,
    thanks a lot for any help
    Arturo
    Arturo Sinclair replied 11 years, 7 months ago 2 Members · 2 Replies
  • Joseph Owens
    January 10, 2015 at 7:10 pm
    [Arturo Sinclair] “The source material is a single 45 min .mov”
    Have you tried exporting a CMX EDL and importing the single movie using the EDL as a cutlist?
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Arturo Sinclair
    January 10, 2015 at 9:24 pm
    Thank you, I will try that, although the problem still remains, why would DaVinci (or the Premiere xml) does not interpret the timecode correctly?
