Activity › Forums › DaVinci Resolve › Davinci for dailies?
Posted by Blase Theodore on February 22, 2011 at 2:50 amI want to start using Resolve for dailies, but don’t know how to deal with the missing audio, specifically for RED.
I’m just looking to sync on camera audio without it getting stripped out. I need it for both FCP and Avid.Anyone got a workflow that doesn’t involve hand re-linking?
Illya Laney replied 15 years, 5 months ago 6 Members · 10 Replies -
Sascha Haber
February 22, 2011 at 9:15 amDont hate me for saying but you dont want to do this.
You want Storm.
Its the one and only solution I was hoping for for years.
Prores files, dnxHD , all metadata preserved, multilayer timeline, and so on..
https://www.thefoundry.co.uk/products/storm/
Give it a try as long as its free.
I just finished a short movie with a Storm-FCP-DaVinci-FCP workflow and it was a breeze.A slice of color…
DaVinci 7.1 OSX 10.6.6
Dual Xeon 2,4 RAM 24 GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE -
Blase Theodore
February 22, 2011 at 12:32 pmYeah but it doesn’t do mxf, which is what I need to deliver.
Blase Theodore
February 23, 2011 at 3:16 pmAnyone care to comment on this workflow?
Which I’m too busy to test…
Resolve grades out MXF from red.
Redcine x renders out MXF and .AAf with audio only checked.
Redcine x renders out .ALEAvid imports .ALE to create offline clips.
Dump all media into avid_mediafiles folder
Avid marries audio and video?Thoughts?
Margus Voll
February 25, 2011 at 5:07 am -
Blase Theodore
February 25, 2011 at 7:53 pmHere’s what I tried..
Avid –
Export mxf audio and video through redcine X.
Export audio mxf only through redcine x
Export video only mxf through ResolveAdd redcine vid and audio mxf’s to avidMediaFiles directory.
Media Tool shows unified clip.Add resolve video and redcine audio mxf’s to avidMediaFiles directory.
Media Tool shows separate audio and video clips.Imported redcine generated ALE. ALE will not relink to Resolve mxfs.
One strange note, if I import a Resolve generated QT or even the source QT, AVID screws up the timecode. CHecking those same QT’s in FCP, the timecode is correct.
– FCP
Imported resolve QT (video only) and source R3d proxy QT (vid and audio) – all timecodes correct.
Overlayed and hand linked resolve QT vid to pxy audio. Tried to export/media manage/mm recompress to create new clips.
All options failed.In both AVID and FCP, all clips were generated with correct timecodes.
Conclusion: There is no way to create dailies with camera audio in resolve.
Adam Hendershot
February 26, 2011 at 1:57 pmYou can merge clips (the seperate audio and video) in the browser, then batch export the merged clips. I did it for one test and it seemed fine. I haven’t figured out a way to automate the process of merging the clips. If you do let me know!
Blase Theodore
February 26, 2011 at 2:14 pmFor FCP, I tried that. But because it was using the R3D audio, it gave me errors.
This may work with other dailies like 5D or Alexa.– Batch export – created the clips, but the clips were bad when I tried to re-import them to test them.
– Media manage copy – fails
– MM recompress – failsEither way, there’s no way to batch link the clips, so its not really an option for me.
Tyler Fagerstrom
March 17, 2011 at 2:29 pmWe’re having a similar set of issues because of the fact that Avid won’t relink to MXF’s. I’m more of an FCP guy, so I may be missing some easy way to do this, but is there a way to import an ALE and link it to Resolve rendered MXF files? Or any kind of MXF file?
High Mercury Productions
highmercury@gmail.com -
Blase Theodore
March 17, 2011 at 3:35 pmThe ALE would be if you wanted to have a file that linked the audio and video. If its just the davinci video mxf you’re trying to bring in, it shouldn’t be a problem.
Load the mfx files into your Avid Mediafiles/MXF/(whatever)/
Delete the database files. Load Avid, create a project which matches your resolution and framerate. Refresh media databases, then use the media tool to search for the files on your drive. -
Illya Laney
April 7, 2011 at 11:59 pmHey Tyler,
Toss the AAF files into a new bin and it should automatically link up to the related mxf’s in the Avid MediaFiles folder as long as the folder structure is set up correctly. After that you merge the ALE with the clips in the bin.
twitter.com/illyalaney
