Activity Forums DaVinci Resolve DaVinci deck output -> AJA KiPro
  • DaVinci deck output -> AJA KiPro
    Posted by Danny Thompson on August 15, 2013 at 4:33 pm
    I’m looking into using DaVinci as a realtime legalization system.
    I have a KiPro and have successfully edited stuff on to it from FCP but can’t seem to get it working with DaV despite trying a lot of different configurations on each end.
    Does anyone here have experience getting the two to work together?
    Danny Thompson replied 13 years, 1 month ago 2 Members · 4 Replies
  • Peter Chamberlain
    August 16, 2013 at 1:30 am
    DaVinci Resolve supports the BMD range of video capture and playback devices.
    Not the Ki.
    Peter
  • Danny Thompson
    August 16, 2013 at 2:35 am
    But isn’t it supposed to support decks in general?
    Oh well. Back to the FCP broadcast safe filter.
  • Peter Chamberlain
    August 16, 2013 at 6:51 am
    Re-reading my post I see I didn’t answer your question. You didn’t mention your video capture card, and I meant to say, you need a BMD card assuming you had AJA connected to the Ki-Pro.
    So, which BMD card do you have on your Resolve and is it SDI you are trying to connect too? Do you have the RS-422 connected for control?
    Peter
  • Danny Thompson
    August 16, 2013 at 12:48 pm
    Haha, yes, actually saying what gear it is always helps…
    Card is a Decklink Extreme HD, Resolve 8, and I am using RS422 control and SDI for video IO.
    When I put bars up on the KiPro I get video in. I can’t get it to detect it otherwise. I turn off the bars before starting to record. Once I start recording, Resolve doesn’t actually output anything over SDI (I’m monitoring it two different ways, I’m sure).
