Activity Forums DaVinci Resolve Davinci ACES color space
  • Davinci ACES color space
    Posted by Kritsada Kaewmani on January 29, 2012 at 4:25 pm
    Hi all,
    I have some questions about new Davinci ACES color space.
    I did some test it’s great really big improvement.
    The default IDT/ODT LUTs are shown below.
    IDT
    -No Input Device Transform
    -RED
    -Alexa
    -Canon 1D
    -Canon 5D
    -Canon 7D
    -Rec709
    ODT
    -No Output Device Transform
    -DCDM
    -P3 D60
    -Rec709
    -ADX
    However I found some problems I’m not sure whether I did something wrong or not.
    1.When I load *.r3d files into Resolve using color science=Davinci ACES, IDT=Red and, ODT=Rec709. The images on screen look yellow. However it can be corrected easily by tweaking the color gain. This happened to Rec709 IDT LUTs as well when I try to load some Rec709 materials. Is this normal?
    2.ADX LUT on the IDT side makes the DPX Log files from scanner extremely bright (using Rec709 as ODT). Finally I found that I have to scale the Code Value of the DPX files down by 4 times exactly before I send them to Resolve to match the same DPX files being shown on others software side by side with the 3D LUT on. For the ADX LUTs on the ODT side the effect is inversed the DPX file rendered out is 4 times darker. I have to scale it up 4 times. It seems like color encoding of ADX LUT use only ¼ of the Full Range, using only 0-1023 out of 0 – 4095 for example.
    3.Canon 7D and Canon 5D IDT LUTs show big difference. Canon 7D is much brighter than Canon 5D. I tested this on the QuickTime from both 5D and 7D.
    Do you have any idea?
    Thank You Very Much
    Kritsada
    Hi there
    Paul Carlin replied 13 years, 4 months ago 4 Members · 6 Replies
  • Kritsada Kaewmani
    January 30, 2012 at 6:57 pm
    Finally, i figured out that there are 2 types of ADX encoding, ADX10 and ADX16.
    ADX10 is nearly the same as the DPX 10 bits log density range=2.046.
    ADX16 has density range=8.191875 ( 4 times of ADX10 ).
    The ADX LUTs in Resolve both IDT and ODT are ADX16.
    I really hope that there will be ADX10 in the next version.
    Bangkok, Thailand
  • Javier Sanchez
    February 4, 2012 at 2:17 pm
    That was great, no body reply me about Aces some month ago, and there is no info on the net about.
    Regards
    Javier Sanchez
  • Kritsada Kaewmani
    February 5, 2012 at 4:53 pm
    I think the ACES/IIF is not new it has been used by people in need of HDR and Wide Gamut color space for a while.
    RED CINE-X can transcode r3d files into OpenEXR format with the ACES color space option.
    Many of VFX/Composite softwares support OpenEXR and ACES.
    Resolve(TM) just added new color science named “DaVinci ACES” I wish i could have more information about it.
    I want to know more about IDT/ODT where are they in the Resolve directories and how it looks like then i can modifiy them or make a new one. Unfortunately there are only few documents about Davinci ACES.
    Bangkok, Thailand
  • Joseph Owens
    March 12, 2013 at 11:47 pm
    [Kritsada Kaewmani] “how it looks like then i can modifiy them or make a new one. “
    You probably don’t want to do that. Only the manufacturers know how to port their sensor data into the ACES colorspace, so IDT’s will come from them exclusively… As far as ODTs go, its somewhat the inverse, so only the display manufacturers will know how to re-map the data so that it will look right/calibrated on their displays, although the true advantage of all this is the consistent exposure values being easier to write into conventional display colorspaces. All this of course is of large benefit to a particular workflow — 4K 16-bit LOG RGB image sequences.
    Unless I am reading this all wrong, Quicktime users are not going to find this workflow particularly useful, even if they get past the really big numbers that are part of the calculation, all in terms of data throughput, storage, and hardware costs. Can’t see it being appealing to those who balk at the price of a certified grade monitor, and ODTs may not be worth the price of admission for graphics display manufacturers.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Kritsada Kaewmani
    March 13, 2013 at 4:46 am
    Thank you for reply
    It’s been one year 🙂 I did some test ands found out pros/cons of grading in ACES color space on Resolve.
    Conversion from other color spaces to/frome ACES is easy as far as we know the chromaticities of them. Unfortunatly grading in ACES on Resolve is not easy. It’s all about the work flow. For example if I finish a shot and render out into Rec709 I will not be able to put some of superimposed text or VFX elements and replace it into the original ACES timeline for re-grade. I have to render out to ACES but this creat anoter problem, many VFX artists did thier job in sRGB so i have to convert VFX elements into ACES. I tried to simplify this by using LUTs in the Resolve timeline but applying LUTs in the ACES mode is not the way to go. ACES is HDR and wide gamut but 3DLUTs are only 17,33 or 64 steps. Applying series of 3DLUTs can causes some artefacts. To meet flexibility and deadline i gave up using ACES for now.
  • Paul Carlin
    May 4, 2013 at 8:29 pm
    The lack of responses is because the people who really understand this stuff are few and far between and earn six figures somewhere under a NDA.
