Activity Forums DaVinci Resolve DaVinci 2008 MacPro Compatibility
  • DaVinci 2008 MacPro Compatibility
    Posted by Dave Barnard on June 12, 2011 at 1:50 pm
    I’m setting up Da Vinci Resolve on a 2008 Mac Pro system and seem to have run into a compatibility issue.
    I am using Fibre Channel RAID storage connected to an Apple/LSI 4Gb Fibre Channel card.
    When the machine boots up, mouse & keyboard clicks are not recognised.
    Apart from this, everything works fine! Cards in the slots are:
    1 NVidia GTX 285
    2 NVidia GT120
    3 Blackmagic Multibridge
    4 Apple 4Gb Fibre Channel card
    I have a feeling that the problem is caused by the Apple Fibre Channel card.
    Although it will operate at full speed in a 4 lane PCIe slot, the board is physically 8 lane.
    8 lanes would exceed the total bandwidth available on the PCIe bus, even though the extra bandwidth is not needed.
    If I put a 4 lane Highpoint eSATA card into slot 4, no problem.
    Has anyone else seen this problem, or used an Atto Fibre Channel card successfully with a 2008 Mac Pro?
    Thanks All
    Dave
    Dave Barnard replied 15 years, 2 months ago 3 Members · 5 Replies
  • Mikhail Puzyrev
    June 12, 2011 at 2:40 pm
    Try to Insert the USB keyboard plug into the USB slot on the MacPro, not in the Apple Cinema Display or any other kind of USB hub.
  • Dave Barnard
    June 12, 2011 at 4:21 pm
    I’m using an Apple Bluetooth Keyboard & Mighty Mouse, but I get the same thing happening with an Apple USB keyboard and mouse plugged into the front port
  • Jason Myres
    June 13, 2011 at 5:49 pm
    [Dave Barnard]
    8 lanes would exceed the total bandwidth available on the PCIe bus, even though the extra bandwidth is not needed.”
    You’re fine. Your slot assignments are perfect. The Apple/ LSI fibre card works in 4x and 8x, but operates at full bandwidth in 4x.
    JM
  • Dave Barnard
    June 13, 2011 at 11:40 pm
    I’ve tested it with another 4Gb Apple Fibre Channel card and it does exactly the same thing.
    The mouse pointer moves, but no clicks are detected and no keyboard input.
    If I leave the machine for some time after booting, both start working again but the Fibre Channel card is not detected in System Profiler.
    If I substitute the 4 lane Blackmagic Multibridge card for a 1 lane Intensity Pro card, the system works but of course has no dual link SDI.
    It should work with the Multibridge & Apple Fibre Channel card, but clearly does not!
    Does anyone have a similar system working or can test with a 2008 MacPro and Apple Fibre Channel card?
    Dave
  • Dave Barnard
    July 22, 2011 at 4:30 pm
    Just swapped out the Apple Fibre Channel card for an Atto FC42-ES and now everything works fine!
    Clearly there is a problem using the Apple card for Da Vinci on this machine
    It looks like the 8x/4x PCIe design of the card is the root of the problem
    Hope this is helpful to someone
    Dave
