Activity › Forums › DaVinci Resolve › Davinchi Lite with GT120
Posted by Dilum Alagiyawanna on August 24, 2011 at 1:53 pmHello,
I have just installed davinchi resolve lite on my Macpro with NVIDIA GT 120
and CUDA version is 4.0.50, but I’m getting e message CUDA driver is not loaded. Can anyone help me to resolve this issueDilum Alagiyawanna replied 15 years ago 5 Members · 9 Replies -
Robert Houllahan
August 24, 2011 at 4:44 pmI don’t think the GT-120 will cut alone, it it is a really low end card.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
Dwaine Maggart
August 24, 2011 at 11:28 pmThe GT120 will work. What OSX version are you using? If anything earlier than 10.6.8, I would recommend getting the 3.2.17 CUDA driver from the Nvidia Mac CUDA area, and installing that.
Also, the Nvidia driver you use much match your OSX version. For 10.6.8 and later, you should use the 256.02.25 version. Earlier you should use the 256.01.00f03 version.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Chris Borjis
August 25, 2011 at 6:37 pmDwaine will these suggested drivers/cuda work on OS X Leopard
or is Snow Leopard required. -
Dwaine Maggart
August 25, 2011 at 6:59 pmIt must be OS X Snow Leopard or higher (i.e. Lion). OS X 10.6.4 or higher. OS X 10.6.7 or higher recommended for Resolve V8.
Dwaine Maggart
Dwaine Maggart
August 25, 2011 at 7:13 pmIt must be Snow Leopard or higher (i.e. Lion). OS X 10.6.4 or higher. 10.6.7 or higher recommended for Resolve V8.
Dwaine Maggart
Dilum Alagiyawanna
August 26, 2011 at 5:23 amThanks a lot, will check it out and get back to you if necessary.
Dilum Alagiyawanna
August 27, 2011 at 9:46 amIt doesn’t resolve my issue, please help me ” Error: The CUDA Driver is not loaded”
Mac OS X 10.6.8CUDA
CUDA Driver Version: 4.0.19
GPU Driver Version 1.6.37.0 (256.02.25f01)Model Name: Mac Pro
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.26 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per core): 256 KB
L3 Cache (per processor): 8 MB
Memory: 12 GB
Processor Interconnect Speed: 5.86 GT/s
Boot ROM Version: MP41.0081.B07
SMC Version (system): 1.39f5
SMC Version (processor tray): 1.39f5NVIDIA GeForce GT 120:
Chipset Model: NVIDIA GeForce GT 120
Type: GPU
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0640
Revision ID: 0x00a1
ROM Revision: 3386Chipset Model: NVIDIA GeForce GT 120
Type: GPU
Bus: PCIe
Slot: Slot-2
Device ID: 0x0640
Revision ID: 0x00a1
ROM Revision: 3386 -
Sascha Haber
August 27, 2011 at 2:19 pmIn your first post you said you have CUDA 4.0.50, what happened ?
A slice of color…
DaVinci 8.0.1 OSX 10.7
MacPro 5.1 2×2,4 24GB
RAID0 8TB eSata 6TB
GTX 470 / GT 120
Extreme 3D+ WAVE -
Dilum Alagiyawanna
August 27, 2011 at 2:23 pmDear All,
Once I reinstalled CUDA driver it’s working now.
Thanks a lot for the support..
