Activity Forums DaVinci Resolve DAV to Avid (gamma and levels)
  • DAV to Avid (gamma and levels)
    Posted by Stig Olsen on January 9, 2012 at 9:23 pm
    I have still not found a satifying gamma solution when transfering material from Davinci to Avid.
    This is what I do:
    1. Export DNxHD, rebuilt databasefiles in the media-folder, drag to bin, set levels to normal or unscaled video.
    2. Export ProRes, AMA import, set levels to normal or scaled video.
    Both examples mess up the gamma. I need to put a gamma correction on the top layer in Avid to make this work.
    I do watch on a proper monitor that is calibrated.
    When importing to AE, Smoke or Flame – everything works fine.
    Some additional information:
    I have tried setting the output monitor (and export) to both scaled and unscaled – and changed to the same setting in the Avid bin.
    I prefer to work with the output monitoring set to normal scale as it then gives the same “signal gamma” on my computer monitor as I sometime want to have control over how the file will look for web.
    Any suggestions on this topic? I would really appreciate any thoughts.
    Stig
    Jef Huey replied 14 years, 8 months ago 3 Members · 5 Replies
  • Jef Huey
    January 10, 2012 at 4:16 am
    Hello,
    Try a tiff sequence. Though I must say that we have had luck with DNx and 1:1 MXF.
    Have you tried exporting a segment of color bars and sending it back and comparing?
    Good luck,
    Jef
  • Stig Olsen
    January 10, 2012 at 9:48 am
    Hi, yes I have tried Tiff.
    Do you work with normal scale monitoring, exporting normal scale and changing to normal scale in Avid?
    It is not viewing correct gamma here.
    Stig
  • Jon Wright
    January 10, 2012 at 4:24 pm
    I have the same problem here, would be very interested in any solutions to the issue.
    Jon
  • Stig Olsen
    January 11, 2012 at 9:23 pm
    Anyone?
  • Jef Huey
    January 11, 2012 at 9:41 pm
    I mean to retest this, but no time.
    Sorry.
    Jef
