Activity › Forums › Apple Final Cut Pro Legacy › Date/Time Super #$%^&!!!
Mark Suszko
November 22, 2008 at 1:28 amSo, if the upload works, here’s a picture of the fame already shown, all I did here was gaussian blur one copy of it on the bottom layer, copy-paste a clean layer above it, and punched a luma key thru it, using a kids’ photoshop knockoff I have here at home, to illustrate roughly what you can do in the technique described earlier. An alternate version is to mask or wipe the blur over the section.
“Oh, you wanted to RECORD that?”
Nicholas Franczyk
November 22, 2008 at 1:34 amYou have to copy the text from the embed code into the post. It seems odd but it works. The uploaded is really just an image hosting tool.
Thanks -
Mark Suszko
November 22, 2008 at 3:40 amI’m having trouble being patient while using dial-up for this from home… also, this sample still is not done in FCP, just some cheap freeware image editor, but it should give a little bit of an idea of how keying the white letters will lead to more of a glass letter look. You could also just key them individually to the nearest correct color pixel as well, you still get the type there but less noticeable.. one more try to upload this tonight, my daughter is antsy to get back on Runescape (grin).
Mark Suszko
November 22, 2008 at 5:41 amYou can see its still going to be there, but here’s the thing: my view is, a single blur applied over the whole area is way more distracting than using composite mode/luma key cropped to just work on that zone, and just tinting the characters black or to whatever color surrounds them, or to the glass effect. Limiting the repair to just the actual white pixels preserves the little bits of clean video all around the letters and numbers, and it breaks it up more than a bar or wipe box would.
