Activity Forums Adobe After Effects Expressions Date countdown?
  • Patrick Grossien
    February 22, 2017 at 4:04 pm
    Dan, this is fabulous. Much better than the numbers effect because of the better font control!
    Is there a way to control the start and end date via keyframes instead of the rate?
    And also: is there a way to add a time counter to it so I can also end at any given date & time?
    Thanks so much!
  • Patrick Grossien
    February 26, 2017 at 3:23 pm
    [Sorry for the double post – I’m just not sure if the reply was done in the correct place.]
    Thanks so much!
  • Ciji James
    September 10, 2019 at 3:53 pm
    Is there a way to alter this expression to count up rather than count down… If not what could be an easy way to do a count up in the british format, say from 4/10/2020 to 20/4/2021???
    startDate = "Apr 30 2012";
    endDate = "Feb 25 1980";
    rate = 2; // counts per second
    d1 = new Date(startDate);
    d2 = new Date(endDate);
    msPerDay = 24*60*60*1000;
    t = Math.floor((time-inPoint)*rate);
    ms = Math.max(d1.getTime() - t*msPerDay,d2);
    d = new Date(ms);
    dy = "" + d.getDate();
    mo = "" + (d.getMonth()+1);
    yr = "" + d.getFullYear();
    if (dy.length < 2) dy = "0" + dy;
    if (mo.length < 2) mo = "0" + mo;
    dy + "/" + mo + "/" + yr
  • Dan Ebberts
    September 10, 2019 at 4:59 pm
    I think this works:
    startDate = "Feb 25 1980";
    endDate = "Apr 30 2012";
    ms = Math.min(d1.getTime() + t*msPerDay,d2);
    d = new Date(ms);
    Dan
  • Dan Darling
    December 1, 2020 at 6:11 am
    Im having a hard time figuring out how to control the interpolation with a slider like you suggested :/ is it just replacing that ‘t=linear..’ line? Cant figure out how that works.
Page 2 of 2
