Activity › Forums › VEGAS Pro › DataVideo HDR-1 standalone H.264 recorder codec issues with Vegas 15 and 16
  • DataVideo HDR-1 standalone H.264 recorder codec issues with Vegas 15 and 16
    Posted by Larry Brewer on March 2, 2019 at 9:03 pm
    I have an issue when trying to edit H.264 mp4 files created with the Datavideo HDR-1 standalone recorder. https://www.datavideo.com/us/product/HDR-1
    BTW, these files look fine, play and edit smoothly in Vegas 12 and 14. But, in Vegas 15 and 16 the video in my preview monitor is very jerky, it stutters, it will jog forward and backward, breakup and show “reptilian faces” on subjects and overall just look horrible. This is with all the preview settings, draft, preview, good, and best. The audio is fine. The video renders look like the playback and are unusable as well. The files play fine in all my players like VLC, PotPlayer, QT Player, Windows Media Player.
    Anyone care to suggest a solution to this one? Is there a way I can go into my Vegas 12 or 14 and retrive the codecs and bring them into Vegas 15 and 16 without causing other problems? Thank you.
    Larry Brewer
    Larry Brewer replied 7 years, 6 months ago 3 Members · 14 Replies
  • 14 Replies
  • George Dean
    March 2, 2019 at 9:24 pm
    Larry, I’m going to start with an assumption, you have Vegas 12 and 14, along with Vegas 15 and 16 still installed on your computer, so you can make a side-by-side comparison and not working from memory….correct?
    Can you post a screenshot of your source media specs using Mediainfo in the Text mode?
    Best Regards……George
  • Larry Brewer
    March 2, 2019 at 9:35 pm
    George,
    Yes. I have all 4 loaded and did back to back trials on a windows 7 PC, Intel i7 4790, 8 thread, 32GB ram.
    The info you requested looks like this..
    General
    Complete name : F:\XXXXXXXXX\HDR1 records\022519 am pgm2\022519 am pgm1 am\022519-1111.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 4.93 GiB
    Duration : 58 min 15 s
    Overall bit rate mode : Variable
    Overall bit rate : 12.1 Mb/s
    Description : AverMedia_HDR-1_001.900.Z03
    Encoded date : UTC 1970-01-01 00:00:00
    Tagged date : UTC 1970-01-01 00:00:00
    Writing application : Lavf53.3.0
    Comment : Quality_FINE
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.1
    Format settings : CABAC / 2 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Bit rate : 12.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 59.940 (59940/1000) FPS
    Minimum frame rate : 59.940 FPS
    Maximum frame rate : 60.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.096
    Stream size : 4.87 GiB (99%)
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Variable
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 53.3 MiB (1%)
    Default : Yes
    Alternate group : 1
  • George Dean
    March 2, 2019 at 11:11 pm
    Larry, your source media looks good with 2 exceptions…..
    Frame rate mode : Variable can the DataVideo HDR-1 record ‘Constant Frame Rate’. Most NLE, including Vegas, do not prefer variable frame rate. I have gotten success in the past with some variable frame rate source, but it is always easier on the NLE to either record Constant Frame Rate, or convert the source before placing in Vegas. I know you say it works in 12/14, but variable frame rate just isn’t the best if we can get constant.
    Is there a specific reason you are recording ‘interlaced’ as opposed to ‘progressive’? There is nothing wrong with interlaced if you are going to render your deliverables in DVD, or Bluray, or for some other reason. If you are publishing on the web, viewing on a PC, or showing on a flat screen TV, you are better off with progressive.
    Have you open Vegas 14 and Vegas 16 at the same time so you can quick switch between them, even size them so you can view them at the same time and then went through the Preferences settings, as well as, the project settings to determine if there is anything different? Although Vegas Pro 14 was distributed from Magix, it is pretty much the same as Sony Vegas Pro 13. In Vegas Pro 15/16, Magix has made considerable changes. Hopefully for the good, although I’m sure you don’t feel that way at this time!!!
  • Larry Brewer
    March 2, 2019 at 11:41 pm
    Frame rate mode : Variable… No the HDR-1 cannot be switched to CBR (constant BIT rate) it always records VBR (variable bit rate)
    Scan type : Interlaced… I’m recording the output of a switcher that is 1080i. 1080i because the cameras the client uses are 1080i
    I’ve checked the project preferences and they are the same. I’m thinking there is a codec in VP-12 and VP-14 that is missing in VP-15 and VP-16. This would most likely be due to the Magix influence. The Main Concept AVC/AAC avc, mp4 render option is missing from the version 15 and 16, but is present in the version 12 and 14. It seems an unlikely coincidence that the the problem follows the absence of that codec, and the successful renders follow the presence of that codec. Now to get that codec into versions 15 and 16. If you’ve got suggestions on how to do that I would appreciate help in that direction. Thanks!
    Larry Brewer
  • George Dean
    March 3, 2019 at 12:51 am
    If that is the case, there is an easy fix. Go Option > and then while holding down the ‘Shift’ key, click on Preferences. This will expose the ‘Internal’ tab, top right, click on it. At the bottom search type in ‘Main’ that will bring up the ‘Enable Legacy Mainconcept’ change the ‘FALSE’ to ‘TRUE’, click on ‘Apply’ then ‘OK’ and you are all set. I don’t think you have to re-start Vegas, but maybe.
  • Larry Brewer
    March 3, 2019 at 1:15 am
    Thank you for that helpful information. I had once known about the “internal” tab and the settings it had hidden from the users. But had long since forgotten how to get there.
    Unfortunately, it didn’t fix the issue. I did restart Vegas 15 after making the change, but still no dice. The Mainconcept render option did appear in list where it wasn’t before.
    I wonder if just returning the render option to the render list is all that would be required. After all, the problem is my ability to play these files that’s compromised. Do you know where I can find the folder that has all the codecs? Is there such a folder?
    thanks,
    Larry BBrewer
  • George Dean
    March 3, 2019 at 3:27 pm
    Hi Larry, I didn’t think that would do you. Before you start messing around with the codec hack, can you record a short segment (not to large in size) and upload it to a sharing site that I can download it and duplicate your issue? Maybe it’s not Vegas 15/16, rahter something in your system. I have Vegas 13/14 trial and Vegas 15/16.
  • Larry Brewer
    March 3, 2019 at 3:50 pm
    try this link
    https://drive.google.com/file/d/1gfVeYNNEMObW3JZoE8gn1vh6pAbxY5mP/view?usp=sharing
    just tested this in 15 and 16 and it will not play. 12 and 14 plays just fine.
    Larry Brewer
  • George Dean
    March 3, 2019 at 5:06 pm
    Hi Larry,
    I have good news and bad news!!
    The Good, you are not going crazy (you knew that), and I’m not going crazy (I wasn’t sure of that)!!
    The Bad, your sample does the same for me as it does for you.
    Actually this may be good news, because we have now determined there is nothing in your system that is causing it, unless we beat the odds of probably a million to 1 that both our systems are screwed!
    I’m thinking maybe this should be posted in the Vegas Creative Software Forums. I can do it if you prefer, but it would probably better if you do. What do you think about that?
    https://www.vegascreativesoftware.info/us/vegas-pro-forum/
  • Ole Kristiansen
    March 3, 2019 at 5:24 pm
    Go to your C-drive – Programs – Vegas – Vegas Pro 16 – FileIO Plug Ins – Rename so4compoundplug to REMso4compoundplug – Vegas pro 16 – will then use compoundplug.dll and you can play your footage !
