Activity › Forums › DaVinci Resolve › database error with Davinci 8 Lite
Johnathan Throbins replied 14 years, 2 months ago 10 Members · 18 Replies
Carl Ballou
November 17, 2011 at 2:50 pmRobert,
I downloaded the newest update and it installed under lion flawlessly!
Here is the link:
https://www.blackmagic-design.com/support/detail/?sid=3948&pid=11735&os=mac&leg=0
Robert Von münchhofen
November 21, 2011 at 1:49 pmThanks Carl that worked for me as well. I had to reconnect the database though and upgrade it manually, but that was no hassle.
Greg Ausina
December 27, 2011 at 10:21 pmThanks Rohit,
Your commands did it for me. The last one contains an error though, you should have written : sudo dscl . -delete /Groups/postgres to delete the user.
I reinstalled resovle lite and the database was successfully upgraded. I still get an error saying I have no cuda GPU but that’s another story.
Regards, Greg.EDIT: cuda error solved: unchecked the switch graphic card option in my macbook pro energy savings prefs
G.Ausina / Gisèle productions / Paris
Carl Ballou
January 2, 2012 at 11:37 pm -
Chris Love
February 1, 2012 at 10:54 pmSteve,
Thanks for posting this. It worked for me on the new 8.2 beta and hopefully will continue to work for Lion users running into this problem.
Ben Battersby
February 6, 2012 at 9:33 pmI Have a macbook 15 i7 2.5ghz and I’m in the same situation (running Lion) I’ve tried all the above and have had no luck. Still has data base error. Ive now got the Resolve update loaded but still the same. any help appreciated
Gregory Kennedy
March 30, 2012 at 7:14 pmhmmm, link doesn’t work anymore and all of the code solutions aren’t applying for me. Still getting the error on the final line – in latest version of lion.
Johnathan Throbins
July 10, 2012 at 7:41 amOne instruction to add to this (i just had this problem and followed Rohit’s directions):
After his instructions, launch Resolve, it will still show “no database connected”. In the database manager select “CONNECT” (not create new) and leave the fields in their default. It will then connect to the newly installed database from your re-install!
P.S. thank you so much Rohit!! You saved me!
