Activity Forums Avid Media Composer Database Error
  • Database Error
    Posted by Paul Allen on January 15, 2009 at 8:19 am
    Hi All,
    When starting up MC I got the following message:
    ‘A database error ocurred when scanning FILENAME’.
    It then gives the option to ignore or quarantine – I’ve been selecting ‘ignore’ and all seems ok, but it’s more than a little disconcerting.
    Is this a problem with the media or the meta-data? What would people advise? If you quarantine is it just simply a case of re-capturing tapes to replace the corrupted files, or is it more serious?
    Paul
    Paul Allen replied 17 years, 8 months ago 2 Members · 2 Replies
  • Dino
    January 15, 2009 at 8:55 am
    Select quarantine next time. By ignoring it, it’s still there every time you start up, thus the re-scan with error. Quarantine will move the bad media into a “quarantine” folder in the media folder. You can delete that folder whenever you wish.
    As the file is corrupt and being ignored, you would have seen it offline already. Chances are it is just a render and not missed.
    I’d like to add a comment on this post and many others. Give us a little info: software version, operating system, hardware, type of storage, etc… You may not think it relevant to your problem, but perhaps it is. And in the larger scheme patterns may emerge of certain problems on specific configurations. No one of us on the Cow can have a hundred test systems but by the fact that we all share information allows us to gain insight into setups we don’t have access to. Further, a post for help that contains very little data can turn into a guessing game. If I want to play a game, I’ll invite some friends over and have them bring a 6 pack and a pizza. That is, if you cant be bothered to offer a detailed description of the problem and the situation it occurs in, why should I bother crafting a reasoned, descriptive answer. Paul, sorry to pick on you. Your post certainly isn’t among the worst. Those questions I don’t bother responding to at all.
  • Paul Allen
    January 15, 2009 at 1:22 pm
    Apologies Dino, I thought my message signature gave my system specs, but have just realised it’s blank. Thought this might just be one of those quick answer ones, but understand the frustration of getting very little to work with.
    Thanks for the reply though, very helpful.
    Right, now to see if this signature works or not…
    Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme QX6800 2.93GHz. 256MB Nvidia Quadro/FX1500 PCIe 1Gb DDR2
