  • Posted by Adam Chesbrough on January 27, 2011 at 4:06 am
    See the attached browser window. You can see the various compressor codec used and the corresponding data rates. I am confused because, for example, the 01042001.mov was recorded in 50Mb/s which doesn’t correspond to 17MB (17 MB equals around 130Mb…unless the conversion tool online was incorrect). Is there any way to change the data rate column to Mb. I just want to make sure I am not losing data during compression (even thought that first file was straight off the CF card. Any insight would be great. Thanks
    macbook pro 17″ i7, 8GB RAM
    esata external HD 7200RPM
    canon 5D mark II, 24-70mm, 50mm, 15mm fisheye, juicedink DT454, zacuto striker
    Rafael Amador replied 15 years, 8 months ago 3 Members · 3 Replies
  • Rafael Amador
    January 27, 2011 at 12:23 pm
    Hi Adam,
    I think that file is coming from a NANO-Flash.
    NANO-Flash uses the SONY XDCAM HD-422 codec, but is not restricted to the official 50Mbps data rate. It can records from 25 to 280 Mbps. However, whatever the real data-rate, it will shows only 50Mbps.
    Nothing wrong.
    Open the file with QT Player and have a look to the Info window.
    Cheers
    Rafael
    http://www.nagavideo.com
  • Chris Gordon
    January 27, 2011 at 9:42 pm
    You mentioned an online conversion tool.. Remember that the conversion between B (bytes) and b (bits) is simply a factor of 8. There are 8 bits in 1 byte. You can easily multiple or divide as appropriate and not need to hunt down any other tool that may give you doubt.
  • Rafael Amador
    January 27, 2011 at 11:01 pm
    Is not a matter of tools. Is that an standard XDCAM HD-422 file can’t make 17 MB/s files because is 50Mbps. As you know 50Mbps should make 6.25 MB/s files.
    I bet that is a NANO-Flash 140Mbps.
    rafael
