Activity › Forums › Apple Final Cut Pro Legacy › data rate warning?
  • data rate warning?
    Posted by Bob Cole on October 15, 2006 at 1:54 am
    Capturing into FCP, using Easy Setup – DV Firewire NTSC 48 khz, from the Sony Z1 HDV camera. The footage was shot as DV on the Z1, and is being output from the camera as DV.
    The footage and audio look and sound good, but almost every time I end a capture, I get a warning that the audio and the video may not sync up correctly due to a mismatch between the source material and the Easy Setup.
    How do I need to adjust my input settings, and do I do it in the camera, FCP, or both?
    Thanks.
    — Bob C
    Bret Williams replied 19 years, 11 months ago 2 Members · 1 Reply
  • Bret Williams
    October 15, 2006 at 3:44 am
    Sounds like you’re probably shooting at 32khz. Use that easy setup instead.
