Activity › Forums › Apple Final Cut Pro › Data Rate versus Bit Rate
  • Data Rate versus Bit Rate
    Posted by Glenn Payne on July 10, 2019 at 8:51 pm
    I look around and couldn’t find anything on this. Also didn’t see a “compressor 4” category so posted in fcpx.
    I’m exporting a Prores 4444 3840 x 1634 short film. The master file is 145.6 GB and the custom made H.264 MP4 at 2048 x 871 is only 3.29 GB. I thought the 3.29 seemed smaller than expected. A friend asked what the bitrate was and I noticed there’s an option for changing the bitrate for DVD exports but not for MP4.
    I did see a “Data Rate” option that ranges from 64 – 30,000. Does the data rate act as the bitrate for digital files like MP4s? Should I raise that number as if it were the bitrate? if so, what’s a recommend number?
    Thanks so much for any advice!
    Glenn
    Glenn Payne replied 7 years, 2 months ago 2 Members · 4 Replies
  • Bret Williams
    July 10, 2019 at 9:41 pm
    Data rate, bit rate, same thing isn’t it? For 4k I’d peg that at 30 because 1080p is recommended around 15.
    ______________________________________________________
    https://BretFX.com FCPX Plugins & Templates
    New Transition Pack! SLIDE WIPES Customizable Wipes that Move
    https://bretfx.com/product/slide-wipes
  • Glenn Payne
    July 11, 2019 at 2:25 am
    Thanks, Bret!
    So for data rate numbers would that mean I would set it at 30,000? (out of the 64-30,000) range.
  • Bret Williams
    July 11, 2019 at 3:32 am
    I create 4K for upload at 30,000 and 1080p at 15,000.
  • Glenn Payne
    July 11, 2019 at 3:40 am
    perfect. Thanks!
