Activity Forums Adobe After Effects data rate different between quicktimes
  • data rate different between quicktimes
    Posted by Rich Ramazinski on March 20, 2007 at 2:46 am
    looking for some verification here…
    I’ve rendered two quicktimes in animation compression (at 16 bit), and have noticed that the data rate is vastly different between the two.
    In Quicktime, when I pull up the Movie Info, the Data Rate for one is about 10 times larger than the other movie.
    Both movies have small amounts of complexity, and for the most part are titles on a flat colored background.
    The longer movie has the lower data rate, which is why I bring this up.
    The longer movie also usually has a flat white background, while the shorter one has various flat colored backgrounds.
    Can this explain the anomaly?
    thanks.
    Rich
    Steve Roberts replied 19 years, 5 months ago 3 Members · 4 Replies
  • Steve Roberts
    March 20, 2007 at 2:50 am
    So the longer one has a lower data rate and a flat white background? I think you have your answer. 😉
  • Rich Ramazinski
    March 20, 2007 at 3:35 am
    I KNEW IT!
    thanks for the response.
  • Majorasshole
    March 20, 2007 at 4:53 am
    solid colors compress better
  • Steve Roberts
    March 20, 2007 at 1:05 pm
    Yep … because it takes less figgerin’ (data) to describe something that doesn’t change spatially (across the frame) or temporally (between frames).
