Activity Forums Adobe InDesign Data Merge – Remove Blank Lines is not working
  • Data Merge – Remove Blank Lines is not working
    Posted by Brandon Little on August 3, 2015 at 10:27 pm
    Hey guys! I’m hoping someone can help as I’ve been scouring Adobe threads and trying scripts to no avail. I’ve got a CSV that I’m using for business cards and when I merge the data, empty cells are NOT being skipped. It’s just adding in blank lines and screwing up my layout. This happens if a field like “Phone 2” is not filled in.
    If I manually just kill the empty line, it wipes that out for all the cards – no good. This is making me batty! Oh, and the text box is set to lock to the bottom. It just seems to be adding in filler as you can see in the hidden chars.
    Thanks for any direction.
    Brandon Little replied 11 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
