Activity › Forums › Apple Final Cut Pro Legacy › data loss during log and capture
  • data loss during log and capture
    Posted by Amit Ghildiyal on May 6, 2009 at 6:06 pm
    I am capturing HDV footage from a Sony HVRZ1U. I am pretty sure im not doing this right because using the log and capture;
    The captured footage is divided in many clips in sequential order
    EXAMPLE: Tape 1-1.mov, Tape 1-2.mov, Tape1-3.mov,Tape 1-4.mov and so on.
    Also some of the data is cut out at the end of clips and start of others.
    Question 1) What setting should I make to capture the entire footage in one clip (like from a digibeta deck) or avoid loss of footage in the captured group of clips?
    Question 2) Does this happen because of dropped frames?
    Amit
    Menachem Daum replied 17 years, 4 months ago 4 Members · 4 Replies
  • John Fishback
    May 6, 2009 at 9:13 pm
    Capture Now starts a capture and ESC will stop it. I have no idea why your clips are truncated. In the future be sure to give yourself more pre-roll before action and post-roll after.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Amit Ghildiyal
    May 6, 2009 at 9:43 pm
    Hi thanks for t your reply. but this is not a pre or post roll issue. I am loosing footage in the middle of the take while capture because multiple clips are being formed.
    (Could it be a camera setting, or am I unable to import HDV 1080i in a single clip becuase of memory issues)
    I work on a
    Powe Mac G5
    2.5 GHz
    2CPUs
    L2 Cache per CPU: 512kb
    Memory 4 GB
    ATI Radeon 9600XT 128MB
    working with 3 external hard drives (One GRAID)
    Kindly help
  • Julio Pijnappel
    May 7, 2009 at 1:48 pm
    I’ve had the same problem very often and what I started doing is capturing HDV directly to ProRes. The files are a lot bigger, but FCP doesn’t bite off chunks of your media. Just change your setup to HDV-Apple Prores, and capturing will be fine. See https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
    Julio Pijnappel
  • Menachem Daum
    June 1, 2009 at 8:00 pm
    Try de-selecting automatic scene detection in the second tab of the log and capture window. Good luck.
