Activity Forums Adobe After Effects Expressions data from nested compositions with Expressions
  • data from nested compositions with Expressions
    Posted by Ariel Levental on February 11, 2009 at 10:22 am
    Hi everyone
    I’ve got a 3d comp with a camera and a scene
    it’s a street and I’ve got a poster on one of the walls
    the comp is huge and I’ve scaled it down to fit a PAL size comp
    i want to put a corner pin effect (or 4 expression point controls) on a solid that represents the poster on the wall
    and i need to be able to link that data to a 2d layer outside the 3d scene so i can bake that data into keyframes and export it.
    i know it must have something do to with the fromComp/toComp expression
    but i just can’t seem to figure it out…
    any ideas would be much appreciated
    thanks in advance
    Ariel
    Ariel Levental replied 17 years, 6 months ago 2 Members · 2 Replies
  • Filip Vandueren
    February 11, 2009 at 1:02 pm
    You’re using the 3D scene as a 2D layer in the Pal comp, right ?
    First off, in the 3D-scene on your 3D-layer “wall” create 4 Point-selectors to locate the 4 corners of the poster.
    Rename the point-controls to “C1” – “C4”
    In your Pal Comp the syntax to get the position of C1 will be:
    precomp=thisComp.layer("3D scene").source;
    wallLayer=precomp.layer("wall");
    // 2D position inside the ful res precomp:
    C1_fulres=wallLayer.toComp(wallLayer.effect("C1")("Point"));
    // 2D position in this comp:
    C1_pal=thisComp.layer("3D scene").toComp(C1_fulres);
    // 2D position on this layer:
    fromComp(C1_pal);
  • Ariel Levental
    February 15, 2009 at 7:48 pm
    Thanks so much
    I’ll give it a try ASAP
    Ariel
