  • Posted by Ben Oliver on July 20, 2006 at 1:32 pm
    hey guys,
    I don’t have toast on my machine yet, but i need to burn a mac/pc compatable data disc (dvd-r).
    does the os tiget built in burning software burn such a disc? i can’t find the info, been searching for nigh an hour.
    thanks everyone
    -ben
    David Bogie replied 20 years, 2 months ago 5 Members · 6 Replies
  • Jerry Hofmann
    July 20, 2006 at 3:25 pm
    iDVD will do it. or DVD SP…
    Jerry
  • 13 Create COW Profile Image
    13
    July 20, 2006 at 3:44 pm
    iDVD and DVD SP do not burn “Data Disks”
    I believe the build in disk buner will work fine
  • Jerry Hofmann
    July 20, 2006 at 4:02 pm
    I was asleep… Just open a blank on the desktop and drag files to it. then when you eject it will ask you if you want to burn it.
    Jerry
  • Ben Oliver
    July 20, 2006 at 4:20 pm
    thats cool, im just wondering if the data will be readable on both macs and pc’s.
  • Vladislav
    July 20, 2006 at 5:25 pm
    From my experiences PCs won’t see the disc if you burn it that way
  • David Bogie
    July 20, 2006 at 9:40 pm
    > From my experiences PCs won’t see the disc if you burn it that way< > I’ve run in to the same issue with PC’s not being able to mount the DVD-ROM disc. Sorry to say only solution I found was toast.< The problems I have with PCs are incompatible readers or old software for the readers. Plus, Mac geeks tend to use 16x media and it doesn't always play well with older and cheaper readers that get installed into cheap PCs. I can burn twelve DVD-ROMs on twelve different types of media and give them to three different PC users. There is no pattern to the go/no-go results of attempting to use the data on the disks. Some open some disks, some can't see some disks. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
