Activity Forums Adobe After Effects Expressions Data Driven Animation: get Color from Json
  • Data Driven Animation: get Color from Json
    Posted by Alex Weil on June 11, 2018 at 4:30 pm
    Hey folks
    i have a color in my Json file
    "textcolor": "[255,0,255,255]"
    now in my footage i got the “textposition” field with an expression on it. how do i get the color informations out of it and apply it to a fill effect on a different Layer?
    cheers
    Alex
    Alex Weil replied 8 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 11, 2018 at 10:21 pm
    I can’t exactly picture what you’re describing, but if you import your json file, you could then use something like this on the color property:
    data = footage(“your_json_file.json”).sourceData;
    eval(data.textcolor)/255
    Note that if you had your color data as an array instead of a string, like this:
    “textcolor”: [255,0,255,255]
    you could eliminate the eval() in the color expression:
    data.textcolor/255
    Dan
  • Alex Weil
    June 12, 2018 at 7:41 am
    sorry, had some little failures in my text … sorry, i meant “textcolor”
    i tried to say, that i only have an expression on the layer, that says “footage(“test9.json”).dataValue([9])” but there was no data that i can use to pick my color from.
    thanks to your answer, i erased the quotation marks from the array and now i got some nice usable data ☺
    thanks dan
