Activity Forums Apple Final Cut Pro Legacy DAT machine nightmares
  • DAT machine nightmares
    Posted by Adam Taylor on October 13, 2006 at 1:49 pm
    I am trying to connect up a Fostex D30 dat recorder to my FCP setup but am having problems getting the setup to work.
    Has anybody managed to connect one of these and if so – please get in touch…you might be able to steer me in the right direction.
    thanks
    Adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Edward G downie replied 19 years, 10 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    October 13, 2006 at 5:44 pm
    Can’t control it? or can’t capture? or? I don’t have one of these decks, but would think you should be able to use it… RS-422 control and use a capture card to capture the analog outs?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Joe Paolo
    October 13, 2006 at 6:21 pm
    In my “Good old linear days” we a Fostex TC dat (can’t remember the model) that we could never controll. Had to buy a Sony 7030 which worked great. Not much help in your case but it may be a lost cause. I would suggest looking for a work around as we wasted weeks trying to get our fostex to work.
    joe
  • Edward G downie
    October 14, 2006 at 2:29 pm
    I have a fostex d10 which is controlable via rs422 with the time code board, but I do not go that rout any more I use my D9 deck and copy the audio via the serial digital output and run the timecode in from the dat to the D9 deck, you can use your ballance audio and timecode out to do the same. I allways have problem with fostex deck menue my pd2 is a nightmare but when I use it I carefuly read the manual and it works good luck.
