Activity Forums Audio DAT and getting the original timecode off
  • DAT and getting the original timecode off
    Posted by Sean Murphy on August 10, 2010 at 4:16 pm
    Can anyone help, I need to digitise the audio form a DAT tape but also bring in the ORIGINAL timecode. If it helps Im mac based using primarily FCP as a video editor, just been asked to step out of specialism 🙂
    Big thanks in advance.
    Sean Murphy replied 16 years ago 2 Members · 2 Replies
  • Peter Groom
    August 10, 2010 at 6:11 pm
    OK
    1st – You must use a tc enabled machine. NOT ABS TC. This means a higher value machine like a Sony PCM 7030 or 7040.
    2 – Control the DAT deck by using a 9 pin control wire (RS232 protocol), exactly the same as if you were capturing from a Digi Beta or HD CAM SR etc etc. It will show up in the VTR preferences so you can set and select the VTR characteristics .
    3) Capture the audio exactly as if it were a Video deck, just plug up the AES/EBU / or analogue outs to the capture machine and away you go.
    The audio recordings will be recorded against the original DAT tc as if it were footage on a VTR.
    Hope this helps
    Peter
  • Sean Murphy
    August 11, 2010 at 8:18 am
    Thank you Peter – perfect.
