Activity Forums Adobe After Effects Dashed line moves when trimming it
  • Dashed line moves when trimming it
    Posted by Stef Prein on May 2, 2015 at 11:48 am
    I’m trying to trim a dashed line and animate that. Growing the line works perfectly fine. Just keyframe the End value from 0 to 100. But shrinking it by key framing the Start value from 0 to 100 makes the line move up. Is there a way to solve this?
    Thanks in advance!
    Stef
    Stef Prein
    director / motion designer at StudioFets.
    Utrecht, The Netherlands
    http://www.studiofets.com
    Brian Charles replied 11 years, 4 months ago 2 Members · 2 Replies
  • Stef Prein
    May 2, 2015 at 12:02 pm
    And something similar happens when I try to let a different dashed line grow. After it has grown, the dashes seem to adjust themselves…
    Stef Prein
  • Brian Charles
    May 2, 2015 at 3:50 pm
    If you’re doing this with a shape layer using trim paths, its likely that the layer’s anchor point needs to move.
    Scale and other transforms are connected to the anchor point.
    Using the pan behind tool to move the anchor point to the beginning of the line should solve the issue.
