Activity Forums VEGAS Pro Darker Sony Vegas Background
  • Darker Sony Vegas Background
    Posted by Roberta Fette on April 20, 2013 at 2:47 am
    I would like to darken my workspace background in Sony Vegas 12 in the same manner as Adobe After Effects and Premiere. I like the dark gray look as opposed to the light gray in Vegas 12. Is there a way I can make it darker? I’ve yet to find a solution other than changing my entire Windows theme.
    Steve Rhoden replied 13 years, 5 months ago 5 Members · 9 Replies
  • 9 Replies
  • Steve Rhoden
    April 20, 2013 at 9:42 am
    If you want Vegas interface darker than the already dark theme
    built in, the only solution is changing the entire windows theme,
    that’s what i do…..
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Graham Bernard
    April 20, 2013 at 10:08 am
    [Steve Rhoden] “the only solution is changing the entire windows theme,
    that’s what i do…..”
    Steve, would you care to share? I get myself so confused with all the options. A ScreenGrab of your Settings wouldn’t take too much of your time?
    TIA,
    Grazie
  • John Rofrano
    April 20, 2013 at 11:38 am
    [Graham Bernard] “I get myself so confused with all the options. A ScreenGrab of your Settings wouldn’t take too much of your time?”
    You need to disable the Aero interface and change to the Basic interface in Windows. Right-click on your desktop and select Personalize, then scroll to the bottom and select Windows 7 Basic. It will make your computer look like you’re running Windows 98 again but you will be able to change all of the window colors to anything you want. I personally hate it but that’s why it’s customizable. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    April 21, 2013 at 6:08 am
    Or you can easily download a windows Dark theme and install it.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Graham Bernard
    April 21, 2013 at 6:16 am
    Steve, have you done this, with a tried and tested? Do you have a link? Don’t wish to corrupt my PC.
    TIA
    Grazie
  • Robert St-onge
    April 21, 2013 at 7:17 pm
    I don’t think there is much you can do in order to achieve a decent darker UI in Vegas. I have tried this several times under Win 7 and also Win 8 to no satisfaction.
    The Vegas UI definitely need some way to adjust the background darkness. I also would prefer it to be darker and making it adjustable, where we could each have it our way.
    I was kind of getting tired of the Vegas color scheme and after 12 years of editing on a regular basis under Vegas, I found out recently that you can, to the very least, change the Track Display Colors which, for the time being, is making my Vegas UI look a little better. I do need some change once in while!
  • Steve Rhoden
    April 22, 2013 at 2:49 pm
    You are wrong Robert, there are a couple safe Windows 7 Dark themes
    that can achieve this.
    I use the dark Windows 7 theme called “LIFE“, Graham.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Robert St-onge
    April 22, 2013 at 5:33 pm
    I understand Steve, but I never managed to get something that was pleasant. Changing the Windows theme affects your entire Windows experience which I didn’t like and didn’t serve me well with Vegas. I would appreciate if you could post a sample of your Vegas UI.
    But Vegas should have that feature built-in just like Premiere has. Let’s face it, you spend countless hours sitting in front of a UI, having some kind of adjustment to make it look darker (or brighter) should be a standard feature.
  • Steve Rhoden
    April 23, 2013 at 7:44 pm
    I also hope there will be a slider feature introduced soon,
    to tweak the darkness and brightness of the Vegas interface.
    Sorry, cant post a screenshot right now.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
