Activity › Forums › Apple Final Cut Pro Legacy › darkening corners
  • darkening corners
    Posted by Chemix Ferreiro on April 24, 2006 at 8:07 pm
    Hi there, I’d like to darken the corners of my final movie a bit, creating a sort of “halo of darkness” and I’m not sure how to go about it so that it looks really nice…
    I’ve tried importing a Photoshop file with a gradient alpha from the center to the four corners but I get banding in FCP.
    Any ideas/solutions?
    Thanks, Chemix
    BUNKER studio
    “edit in paradise”
    Garry Mcgovern replied 15 years, 7 months ago 4 Members · 6 Replies
  • Bouncing Account needs new email address
    April 24, 2006 at 8:18 pm
    Effects > Video Filters > Matte > Mask Shape > Oval (make it the right size)
    add the “Mask Feather” filter and adjust to taste.
  • Chemix Ferreiro
    April 24, 2006 at 8:38 pm
    That’s a good one!
    Now if you wanted to adjust it on a clip by clip basis depending on overall luma…? will you still use this method?
    Thanks a lot
    Chemix
    BUNKER studio
    “edit in paradise”
    April 24, 2006 at 8:51 pm
    [chemix] “Now if you wanted to adjust it on a clip by clip basis depending on overall luma…? will you still use this method?”
    If you create a new video track ABOVE your video, drop the “Slug” onto that track, then add your “matte” effect to the Slug (and “razor blade” it to the length of each clip below) you can adjust the opacity (therefor its “darkness”) of the upper track effect over each individual video clip.
  • Paul Nevison
    April 24, 2006 at 9:35 pm
    I’ve found also adding the multiply composite mode to the slug with an oval applied, gives a nice subtle vingette look. on a shot by shot basis you can also use the soft edges filter under the matte category in the filters tab
    G5 DP 2.0
    4.0G RAM
    OS 10.4.6
    QT 7.0.4
    FCP 5.0.4
    BMD Decklink Extreme 5.5.1
    PAL Land
  • Chemix Ferreiro
    April 25, 2006 at 9:32 am
    Wow, looks great & nice functionality too!!!
    Thanks again for such a quick response
    Chemix
    BUNKER studio
    “edit in paradise”
  • Garry Mcgovern
    February 5, 2011 at 9:26 am
    Bet you didn’t think you’d still be getting thanks for that post 4 years later – but you have just given me the answer I’ve been looking for! Many thanks mate, you’ve given the advice that keeps on giving! Haha!
