Activity Forums Adobe After Effects Dark vs light
  • Dark vs light
    Posted by Cam Panlock on April 4, 2006 at 9:57 am
    Ive noticed when working on projects where i want a dark room or sumthin dark looking on monitor it is fine(pc) but sometimes when this converts to either a mac or tv screen its way darker.
    Is there a way i can kind of see what the darkness will be as a standard to most tvs. Is there a standard or sumthin i can look at. i want darkness to my scenes but i dont want it so u cant see on tv. i could just send it out to a tv screen i know but i want to be workin frame by frame and changing light all the time.
    Should i worry about this or does everyone just have dark telvisions and macs are set differently?
    This project is for short film festivals so i dont want to give them something they cant see. some views and help would be nice cheers. I guess this question is in after effects because there might be a handy way to look at the final darkness of it.
    cheers
    cam
    Andrew Yoole replied 20 years, 5 months ago 3 Members · 2 Replies
  • Creighton Matthews
    April 4, 2006 at 12:21 pm
    Well, chances are you may not be working within proper NTSC colorspace. That is the safe color range that can be displayed on a TV or NTSC monitor. There’s a helpful AE tutorial on here that explains that pretty well. Also, your computer monitor may need to be properly calibrated as far as colors go. Just because it looks a specific way on your monitor doesn’t mean that it’s an accurate representation of the actual colors being used. Hope this helps.
  • Andrew Yoole
    April 4, 2006 at 1:41 pm
    After Effects has a Video Preview function that enables you to view your footage on a video monitor via Firewire and other devices. The ONLY way to reliably check your video work is to watch it on a video monitor.
    Apple computers at default settings run at a different gamma level than PCs.
