Activity › Forums › Adobe After Effects › Dark Bags Under Eyes…..removal.
Posted by Niccolò Ungaro on December 9, 2011 at 11:07 pmIs there a miracle to accomplish in AF for eye’s dark circles removal…?
I’m ok in Mocha….
Thanks & regards.
Nic.Rousselos Aravantinos replied 14 years, 9 months ago 4 Members · 11 Replies -
Darby Edelen
December 10, 2011 at 12:02 amIf you’re ok in Mocha then you should be pretty much set. Tracking bags under the eyes would be the tough part.
For improving the baggage I recommend using a solid that is roughly the color of your subject’s skin with a feathered mask, set to the Normal blend mode with a lowish opacity (try something around 20% to start with). This will move the bags closer to the average skin color without entirely replacing the detail that is naturally present in the area.
Darby Edelen
Niccolò Ungaro
December 10, 2011 at 2:24 amThank Mr. Darby,
yes a solid feathered mask could be a good start. I have also some wrinkles to (in the eyes dark circles) i will like to get rid of..The jung guy is only 89 and i will like him to be happy……I need a way to subtract the black wrinkles from the bags…. maby some alfa trik….
Grazie Darby. Nice
December 10, 2011 at 12:00 pmI’d recommend u to run a track over the eyebrows features as 2layers in mocha.
Make 2 nulls in AE, offset them to be placed in the area you need to “heal”
Then check how well they respond as the tracking data comes not from this area.
Later make 2 adjustment layers, parent them to nulls Left and Right.
Offset-fix any drifted track directly by positioning those adjustments kith key frames.
Draw a mask for each one, add median filter, and use “lighten”
as blending mode.You can duplicate those median layers, setting them as 50% opacity and set them ass normal.
Precomp those layers and nulls. Then use match grain.
Niccolò Ungaro
December 10, 2011 at 2:28 pmGreat Steve,
the match grain trik is a good suggestin.
My worries are the dark wrinkles.I will try some inverted luma with above some alfa….Well i don’t now right now.
Grazie Mr.Agriosi.
Thanks.
Nic. -
December 10, 2011 at 2:57 pmhey,
u don’t need to worry about wrinkles.
Median with a value about 7 will do very good job. then by letting this adjustment layer as lighten
will keep some natural texture of your master clip, but will keep out all the dark wrinkles.
Just tune the second adjustment as normal having some opacity.
You can also add a levels filter on each adjustment.
Do the match grain on a precomp only.
otherwise the motion of the tracking will make grain less visible (4 more if motion blur is enabled )
while the face moves.Take a look here :
https://www.youtube.com/watch?v=1qEtYa94h-Q&list=UUtApqGIDOSbm_XnuxTPDV6A&feature=plcpSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Niccolò Ungaro
December 10, 2011 at 3:01 pmFatastic Steve !
I will do so.
When in my post i will contact you if some problems shows up.
Grazie tante amico!
All my best from Rome.Nic.
Niccolò Ungaro
December 10, 2011 at 8:29 pmnicung(at)hotmail.com.
See you soon.
Grazie for your kind friedship. -
Danny Hays
December 10, 2011 at 10:22 pmThat’s really amazing! Did you make this video? You should make a video tutorial on your techniques.
