Activity Forums Adobe After Effects Expressions dan’s “Layer Invisible When Facing Away” expression quick question
  • dan’s “Layer Invisible When Facing Away” expression quick question
    Posted by Al on December 3, 2008 at 9:13 am
    if (toCompVec([0, 0, 4335])[2] > 0 ) value else 0
    i’m following Dan’s “Layer Invisible When Facing Away” expression, incredibly useful that it is!! Just have a quick question. Here’s the expression i’m referring to:
    i can understand each aspect of the expression, except for
    [2] > 0
    What is the 2 for? And what is the (presumably) Less Than Zero for?
    Would really appreciate thoughts (especially ones for non-expression peoples like myself!)
    Dan Ebberts replied 17 years, 9 months ago 2 Members · 1 Reply
  • Dan Ebberts
    December 3, 2008 at 2:16 pm
    Yikes. Where did the 4335 come from?
    In any case, the [2] just tells the expression to look at the z component of the vector created by toCompVec(). Then, if that value is greater than zero (>) it leaves the opacity alone, othwise (meaning the layer is facing away from the camera/comp view) it sets the opacity to zero.
    Hope that helps.
    Dan
