Activity Forums Adobe After Effects Dangle effect with separated shape layers
  • Dangle effect with separated shape layers
    Posted by Destynie Ellis on August 4, 2016 at 4:02 pm
    Hello All,
    I have an AE project in which there is supposed to be a light bulb on a chain that clicks on with a pulling action. The only part seen is afterward when both the pull chain and lightbulb dangle after the pull. I have tried puppet pin tool, but it doesn’t work as the chain is represented from multiple shape layers (see picture). I was wondering if anyone else had this problem or a solution.
    Kalleheikki Kannisto replied 10 years, 1 month ago 3 Members · 2 Replies
