Activity › Forums › Adobe Premiere Pro › Danger to having lots of audio channels?
  • Danger to having lots of audio channels?
    Posted by Patrick Kilchermann on November 11, 2013 at 5:35 pm
    Hello guys!
    I had to repeat the same audio clip a bunch of times, but I needed to use different tracks to do it, because they had to overlap (all in the duration of a couple seconds).
    Should I be building this audio in Audition, or is it acceptable to use Premiere audio tracks in this way- synonymous with a “layer” in Photoshop?
    THANK YOU!
    Patrick Kilchermann replied 12 years, 10 months ago 2 Members · 2 Replies
  • Ivan Myles
    November 12, 2013 at 5:52 pm
    Premiere should be fine. Audition is preferred when significant processing is required (i.e. applying audio effects).
  • Patrick Kilchermann
    November 12, 2013 at 5:53 pm
    Thank you very much, Ivan!
    Pat
