danel shader_render error
Hi, I created a very short text animation and applied a danel shader as materials. On rendering out, one of the shaders (exterior) came out fine but the interior one has intermittent block artifacts appearing on the front face (most noticable in the video on the front of the S).. Would greatly appreciate if you could look at the video and suggest why this is
Thanks, fran
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
