Activity › Forums › Adobe Premiere Pro › Dancing to beat of music effect
  • Dancing to beat of music effect
    Posted by Movie Maker on December 23, 2006 at 9:19 pm
    Hi, I have footage of a dancer at a disco but I want to change the music and change the timing of his dance.
    I want to try and add ‘Crazy Frog’ tune and get my dancer to move to the beat. I think reversing footage is the obvious solution so he moves back and forth etc but is there an easy way to set up key frames so the footage will match the audio automatically or do I have to set up each beat?
    or is this project best suited to After Effects?
    many thanks
    Jimmy
    Movie Maker replied 19 years, 9 months ago 3 Members · 3 Replies
  • Vince Becquiot
    December 23, 2006 at 11:14 pm
    Definitely After Effects if you want automation. Cycles are very easy to setup in AE.
    Vince
  • Aanarav Sareen
    December 24, 2006 at 2:16 am
    Hmm, it’s going to be pretty difficult, especially if you plan on changing dance moves itself. However, you can easily replace the audio by importing the new song, place it on track # 2 and muting all other tracks.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Movie Maker
    December 27, 2006 at 6:37 pm
    Many thanks, I should have posted in After Effects (sorry!)
    Have now found time remapping on After Effects and am making slow progress with that.
    Thanks again
    Jimmy
