Dancing Bars with Music and Effects
Posted by Accountclosed on November 28, 2005 at 2:00 pmhow can i put the audio effects like…. if a man sings then during singing his voice change tempo (you know what i mean) i mean tempo in different kind
tempo mean when he sings then some audio effects change his voice theme (infact i don’t remember any song that i can use as a sample)Dumb Question !!!
as we can see in many programs they put some effects that shows some bars or equlizer or graphics they move up and down with music can i do in vegasTerje A. bergesen replied 20 years, 10 months ago 5 Members · 7 Replies -
Jeremy Rochefort
November 28, 2005 at 7:26 pmCan do in Vegas. Haven’t done this myself but two video tracks should do the trick – or more depending on the amount of sliders you would want to animate, for example, or simulate a graphic equaliser.
Top track(s) would have your slider image(s) to which you would apply key frames as the music changes to move your slider up and down.
The video track below would containing the static image of your equaliser. Just remember that your slider(s) images would have to be done in a PNG format or similar using a program that supports these kind of images – eg. Photoshop or Paint Shop Pro
Good luck
Jeremy
MJ Productions
Accountclosed
November 28, 2005 at 8:52 pmso you mean i should have to create Equalizer my self and move slides up and down my self but in some videos the use diffrent effects instead using of bar equlizer they use digitle equlizer (LINE) that change the shape or broke or move up and down with music and when music slow it goes slow as a sample you can see in winamp
Thanks for your Help
ALI
Peter Wright
November 29, 2005 at 12:41 amA possible way is to use media player to play the audio – MP has a range of different bars, wavy lines etc which respond to the audio. With a screen recorder such as Camtasia, this couls be recorded and added to the timeline.
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Accountclosed
November 29, 2005 at 5:23 amYa Peter that’s a good trick ummm i did’nt thought about that bob thanks for that thanks alot
Regards
ALi
Graham Bernard
November 29, 2005 at 7:00 amPeter? I’m not5 sure Camtasia will capture Windows Media Player output? I cold be very wrong. However, depending on the final quality you ARE after, a quick ‘n funky way is to actually video a screen directly to camera – yeah? PLUS having the audio being captured simultaneously with this method you will also have a “synch” when you get to the timeline.
Grazie
Peter Wright
November 29, 2005 at 7:22 amGood point Grazie – I’m a bit vague on these screen record/overlay matters – but as you say, videoing preferably an LCD screen to avoid flickers could yield good results.
Terje A. bergesen
November 30, 2005 at 5:12 amAlso, depending on your video card, you can have the display part of Windows Media Player go to your secondary monitor. My Matrox video card can send the video signal to my secondary monitor out a SVideo port on the card, which I can plug into my Camcorder, and voila, nice recordings.
This depends on your video card though.
Terje A. Bergesen
