Activity › Forums › Adobe After Effects Expressions › Dan expression spring? Physic laws?
  • Dan expression spring? Physic laws?
    Posted by Rafael on July 24, 2006 at 5:41 pm
    I have been using this expression from Dan Ebberts. It sort of work, but I wonder if it could calculate the velocity from the previous keyframe to the next keyframe and calculate how much the spring effect is been affected. Calculating the pixel/per second?
    Extra thought: Wouldn’t be great to see a plug-in developped by Dan that mimics different the physics of law? I heard that Motion 2 does some of that, but I am an After Effects person…
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){
    value
    }else{
    t = time – key(n).time;
    veloc = 12
    amplitude = 330;
    decay = 3;
    y = amplitude*Math.cos(veloc*t)/Math.exp(decay*t);
    value+[y,y,0];
    Rafael replied 20 years, 2 months ago 3 Members · 4 Replies
  • Dan Ebberts
    July 24, 2006 at 7:40 pm
    It sounds like you want something like the old Motion Math spring script. George Polevoy posted an expression a few years ago that works pretty well:
    // AE expression by George Polevoy
    // http://www.creativecow.net
    // attaches an object to a “Controller” object with a “spring”
    // You need another “Controller” which will drive animation of this one
    // parameters
    conserveMotion = 0.95; // valid range: 0.5 to 0.995
    springResistance = 10; // positive values
    prerollTime = 2; // value in seconds. greater values give more precise result
    fps = 1.0 / this_comp.frame_duration;
    if ( prerollTime > time ) prerollTime = time;
    dt = this_comp.frame_duration;
    frame = time * fps;
    integrationTime = time – prerollTime;
    s = [0,0];
    p = this_comp.layer(“Controller”).position.value_at_time( integrationTime );
    i = frame – prerollTime * fps;
    for (; i < frame; i++, integrationTime += dt ) { c = this_comp.layer("Controller").position.value_at_time( integrationTime ); d = c - p; s = s + d * springResistance; s = s * conserveMotion; p = p + s * dt; } Dan
    Activity
  • Rafael
    July 24, 2006 at 10:28 pm
    Hello Dan, thanks for answering.
    It does not work well. tarting from keyframe ‘A’ to keyframe ‘B’, the layer behaves strangly, it sort of shakes. What I am looking for is a spring effect that occurs after the keyframe B is done calculated on the speed.
    It seems like yours was closer to the answer.
  • Ryan Hill
    July 25, 2006 at 4:57 pm
    Did you try playing around with the “parameter” values?
  • Rafael
    July 26, 2006 at 11:44 pm
    I tried changing those numbers.
    But it still doesn’t achieve the simple move from keyframe A to B with a spring effect after keyframe B.
    I guess it’s not possible. 🙁
