Activity Forums Adobe After Effects Dan Ebberts’s Universal Counter use comma instead dot for decimal + use checkbox
  • Dan Ebberts’s Universal Counter use comma instead dot for decimal + use checkbox
    Posted by Julien Des on March 22, 2022 at 12:53 pm
    <div>Hello all,</div>
    I need to update this expression but I cannot replace the dot used for decimal separation
    If anyone has an idea on the how to acheive this. It looks like the dot is default sign.
    + I wonder if there is a way to link the false/true values with the checkbox. All I got is a bunch of syntax errors.
    Thanks for the help. And of course, all credits goes to Dan for this (still) usefull script.
    original code is available here =
    https://www.motionscript.com/design-guide/counter.html
    Filip Vandueren replied 4 years, 6 months ago 2 Members · 3 Replies
  • Filip Vandueren
    March 22, 2022 at 2:03 pm
    Hi Julien,
    with the new Javascript engine you can leverage Javascript’s Number internationalization, so it can automatically format a number for your desired locale.
    For example, in Germany (de) they use comma’s and put the currency symbol at the end.
    beginCount = -1999;
    endCount = 1999;
    dur = 4;
    t = time - inPoint;
    s = linear (t, 0, dur, beginCount, endCount);
    new Intl.NumberFormat('de', { style: 'currency', currency: 'USD'}).format(s);
  • Julien Des
    March 23, 2022 at 2:59 pm
    Hi Filip and thanks for this quick answer. I don’t know that much in scripting, so I just pasted your code with no result… do I have to add another piece of code somewhere ?
    [between I changed to Javascript expression engine with no luck again]
    thx
  • Filip Vandueren
    March 23, 2022 at 4:22 pm
    Hmm, no this code should work on the sourceText property of a textlayer if you have the Javascript engine enabled.
