Activity Forums Adobe After Effects Expressions Dan Ebbert’s Squash and Stretch on marker not working correctly
  • Dan Ebbert’s Squash and Stretch on marker not working correctly
    Posted by Andrey Sibiryakov on September 8, 2012 at 9:32 pm
    Hello.
    I’ve combined two expressions one – Dan Ebbert’s Squash and Stretch.
    Only thing it is doing wrong – is doubling scale when assigned.
    Where is a mistake?
    Thanks in advance.
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time){
    n--;
    if (n == 0){
    value;
    }else{
    max_dev=20; // max deviation in pixels
    spd=35; //speed of oscillation
    decay=10; //how fast it slows down
    t = time - marker.key(n).time;
    x = scale[0] + spd*Math.sin(max_dev*t*2*Math.PI)/Math.exp(decay*t);
    y = (1/x)*10000;
    value + [x,y];
    Dan Ebberts replied 13 years, 12 months ago 2 Members · 3 Replies
  • Dan Ebberts
    September 9, 2012 at 1:02 am
    It looks to me like you’ve got spd and max_dev swapped. (spd should be inside Math.sin() and max_dev should be outside).
    Dan
  • Andrey Sibiryakov
    September 9, 2012 at 6:43 am
    Replaced values.
    Unfortunately, didn’t work.
  • Dan Ebberts
    September 9, 2012 at 7:09 am
    This works for me.
    Dan
    n = 0;
    n--;
    if (n == 0){
    value;
    }else{
    x = scale[0] + max_dev*Math.sin(spd*t*2*Math.PI)/Math.exp(decay*t);
    y = (1/x)*10000;
    [x,y];
