Activity Forums Adobe After Effects Expressions Dan Ebberts Light Falloff & Digieffect Light Falloff Plug-in
  • Dan Ebberts Light Falloff & Digieffect Light Falloff Plug-in
    Posted by Chris Trollen on December 14, 2009 at 9:32 pm
    I downloaded a trial version of the Digieffects light falloff plug-in (https://www.digieffects.com/product/falloff_lighting) and played around with it but was not entirely satisfied with the results (I am new to After Effects so it could be me in the way I set up the layers and I may be looking for something that is not fully possible in AE).
    I wanted to compare it with the expression that Dan Ebberts wrote for light falloff utilizing the Diffuse & Specular material properties https://www.motionscript.com/design-guide/falloff.html, and I was wondering if anyone knows how to adapt this expression for more than one light in a scene – it is completely beyond my very basic knowledge of expressions.
    Any help, guidance and input would be great.
    Many thanks
    Chris
    decay = .005;
    noFalloff = 200;
    L = thisComp.layer("Light 1");
    d = length(L.transform.position,transform.position);
    if (d < noFalloff){
    value;
    }else{
    value/Math.exp((d - noFalloff)*decay);
    Eoin Ryan replied 14 years, 11 months ago 5 Members · 5 Replies
  • Dan Ebberts
    December 14, 2009 at 10:49 pm
    Something like this maybe:
    decay = .005;
    noFalloff = 200;
    accum = 0;
    for (i = 1; i <= thisComp.numLayers; i++){ if (index == i) continue; try{ thisComp.layer(i).lightOption.intensity; L = thisComp.layer(i); d = length(L.transform.position,transform.position); if (d < noFalloff){ accum += value; }else{ accum += value/Math.exp((d - noFalloff)*decay); } }catch(err){ continue; } } Math.min(accum,value) Dan
  • Chris Trollen
    December 14, 2009 at 11:29 pm
    Mr. Ebberts,
    This is terrific! – I just tried a quick test and it looks like it will be just the thing I needed.
    Thank you very much for going to the trouble to do this (and I am stunned at how quickly!)
    Regards,
    Chris
  • Michael Szalapski
    December 16, 2009 at 8:07 pm
    The Ebberts is astonishing that way.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Paul Belliveau
    January 15, 2010 at 7:56 pm
    Hi Dan,
    First, thanks for cranking out these solutions. I tried to cut and paste the above “multiple light” solution into the diffuse property and AE returned this error:
    After Effects warning: Expected: ;
    Expression disabled
    Error occurred at line 5.
    Does this make sense to you? FWIW, I’m using CS3.
    Paul
  • Eoin Ryan
    October 28, 2011 at 10:59 am
    Hello,
    I was wondering if this expression works when applied to a nested comp. Should the layers within the comp respond to the expression? I’ve tried applying it and it doesn’t seem to have any effect.
    Eoin
    Intel Mac, AE CS4.
