Activity Forums Apple Final Cut Pro Damn autosave stops working and I’m pissed
  • Damn autosave stops working and I’m pissed
    Posted by Jean-françois Robichaud on September 27, 2011 at 4:13 pm
    I just lost over an hour of editing work because FCP X had stopped saving my edits for some reason. This isn’t the first time it happens; the telltale sign is when the undo feature stops working. I’ve read about others being hit with the same bug. After quitting FCP X and relaunching it, autosave and undo were still not working. I had to quit FCP X again and relaunch multiple times for it to start working properly.
    Any idea of what might be causing this? I like the design of FCP X but I’ve been avoiding using it for anything major because of instabilities like this.
    Andy Neil replied 14 years, 11 months ago 4 Members · 4 Replies
  • Craig Seeman
    September 27, 2011 at 6:05 pm
    Have you upgraded to 10.0.1?
    Are you on OS 10.7.1?
  • Eric Santiago
    September 27, 2011 at 6:06 pm
    This happened once to me but it was around the first week.
    Now during FCPX time, I will check the dates on my Events and Project files to see if its updating.
    Now since that first time, I havent ran into that problem.
  • Jean-françois Robichaud
    September 27, 2011 at 6:44 pm
    I upgraded to 10.0.1, but I am still on Snow Leopard.
    By the way, it happened again, I just lost another 30 minutes of work. I can’t believe this!
  • Andy Neil
    September 27, 2011 at 6:50 pm
    Have you tried to duplicate your project when you notice that the Undo feature isn’t working (before quitting)? This is not a solution to why autosave isn’t working for you, but it may help prevent you from losing work each time it does.
    Andy
    https://www.timesavertutorials.com
