Activity › Forums › Apple Final Cut Pro Legacy › Dammed text!!!
Dammed text!!!
Posted by Sergio Deustua on October 5, 2006 at 5:44 pmDon
Sergio Deustua replied 19 years, 11 months ago 7 Members · 10 Replies -
Ed Dooley
October 5, 2006 at 5:49 pmGive more info! What kind of text, what text generator, what size text, how are you viewing it?
Ed -
Shane Ross
October 5, 2006 at 6:23 pmEditing a DV project? Your text will look bad for as soon as you drop it into the timeline, you are adding the 5:1 compression of DV.
For your text to look good, you need to work in a DV50 or uncompressed 8-bit timeline. But only after you have finalized your cut and are ready to output. However, if you are outputting back to DV, then this won’t work as you need to go back to a DV sequence to output. But this works great if you are outputting to DVD or digibeta or DV50.
Shane
Littlefrog Post
http://www.lfhd.net -
Phillip Van west
October 5, 2006 at 6:36 pmAre you using Title3D (the Boris titler, which came with FCP)? It looks (and IS) a lot better than the generic text generator that also comes with FCP.
Also, be sure you’re checking your text on an external monitor (as you should be for everything you edit). Don’t judge quality with the Viewer or the Canvas.
pvw
Phil Van West
Terra Nova Productions LLC
Denver, CO
Video Production/Post-ProductionG5 DP 2.5GHz / 4.5 GB RAM / OS 10.4.8 / FCP 5.1.2 / QT 7.1.3
Ben Holmes
October 6, 2006 at 1:50 amAs many similar previous enquiries will confirm – All text and gfx/stills look terrible in the viewer. You have to look at them on your monitor – via firewire or video output card. Even with DV timelines, you will get crisp clean text when you output – just avoid bad fonts or bad sizes, not all are suitable for video. Start with Arial bold if you want to compare it to something – that always looks pretty clean.
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live OB operations. FCP systems just used on Sky Sports coverage of the Ryder Cup – live from the K Club.
“The Supercar Run” now available for international distribution from http://www.electricsky.com
Bret Williams
October 6, 2006 at 5:27 amNot completely true. While DV is a a very slightly compressed format, it doesn’t affect text THAT much. It’s 5:1 compression occurs almost all in the color information, not in resolution. Dub a digibeta of something with beautiful text directly to a DV tape via component or sdi and see if the text looks bad. It does not. Usually the problem is with FCP or user error or both. Example, placing text on an odd vertical number in the motion tab. Make sure all text is on an even pixel. 2, 4, 6 etc. not 1.37 or 2.46, etc.
The text should be better looking in fact in the canvas window at 100% or 50% with any sq pixel correction turned off. It’s displayed as uncompressed RGB there. But on the ntsc you’ll see the DV compression. And oddly enough you’ll see more issues with the compression if you’re looking at it with a svideo or component signal. If you look at it with a composite signal (as most viewers will) the compression artifacts melt away.
Sergio Deustua
October 6, 2006 at 8:28 amMy project is a DVCPROHD 720p60 project, and I have tried everything: regular text tool, boris, photoshop, livetpe…nothing works.
Text size 30 to 45, placed over photographs.
Thanks. -
Bouncing Account needs new email address
October 6, 2006 at 1:08 pmMany posters have asked HOW are you checking the quality.
You must be viewing on an external video monitor and not on the computer monitor).
You must render the text at the highest quality setting before judging the quality.
October 6, 2006 at 1:12 pmAnd please read the following link-
https://www.creativecow.net/articles/hodgetts_philip/titles/index.html
It examines DV and resolution.
Sergio Deustua
October 6, 2006 at 4:33 pmIm monitoring in both video and computur monitor. Im rendering in the hiest quality…and nothing.
Ill read the article. -
Sergio Deustua
