Activity Forums Adobe After Effects Damaged Project Recovery
  • Damaged Project Recovery
    Posted by Brandon Dennis on April 5, 2009 at 10:23 pm
    Is there any way to recover my damaged project file? My computer inexplicably froze while I was editing and I had to reboot. When I tried to open the file, it says “File Damaged” and won’t open.
    I have already tried a number of different solutions, none of which have worked. The project was saved in 7.0, and I tried opening it in CS3. I tried importing it as footage in both 7.0 and CS3. I tried putting the project file on another computer that has CS3 installed, in order to open it and re-save it, but it would not even open. I tried renaming the folder that contains all my footage in order to do the same thing, and it failed, for both CS3 and 7.0.
    Does anyone have a solution for repairing this file? I’ve lost a day’s worth of very tedious composting that will take me another day to redo, otherwise.
    Thanks for the help!
    Lukas Boeck replied 14 years, 10 months ago 3 Members · 4 Replies
  • Chris Wright
    April 6, 2009 at 12:06 am
    was autosave on? did u delete any old project files?
    i know file scavenger can recover things, but if AE somehow overwrite one and only one copy of the project, you will have to
    try opening after effects, then importing that messed up project file as if it were just a footage file. AEP files import into AE as their own little folders, so you can then go through and try to find what got corrupted.
  • Brandon Dennis
    April 6, 2009 at 3:30 am
    Sadly, importing the file did not work for me–I get the same error message.
    File scavenger is just for finding deleted files on your hard drive, right? I don’t think it will help with fixing my current project file.
    Does anyone know anything that will?
  • Brandon Dennis
    April 6, 2009 at 6:06 pm
    Wow, damn. I think I just got burned.
  • Lukas Boeck
    October 29, 2011 at 1:20 am
    i pointed to something like a chance over here:
    https://forums.creativecow.net/thread/2/844272
    heaps of threads, nobody ever thought of that. hail to me!
