Activity Forums Apple Final Cut Pro Legacy Daisy chained external hard drives
  • Daisy chained external hard drives
    Posted by Ned Weisman on January 17, 2010 at 1:14 am
    Does anyone know if there is a limit to how many external hard drives one can daisy chain together before functionality is affected?? I’ve got 5 hooked up now and it doesn’t seem to be a problem. However I took one off, even after ejecting it properly, FCP thought it was a drive needed for autosave (it was not) and crashed.
    Michael Sacci replied 16 years, 8 months ago 4 Members · 4 Replies
  • Will Salley
    January 17, 2010 at 4:44 am
    We need more info.
    Primary System Info –
    Mac Pro 2×3.2 Quadcore – 10.6.2 – QT 7.6.3 – 20 GB RAM – nvidia8800GT – SATA internal & external storage – Blackmagic Multibridge Pro – Open GL 1.5.10 – Wacom Intous2 tablet – AJA io
  • Will Salley
    We need more info.
    How are the drives connected? SCSI, Fibre, eSATA, Firewire, etc.
    Are they Raided? If so what level?
  • Rafael Amador
    January 17, 2010 at 5:42 am
    Hi Ned,
    The limit (guess you talking about FW) is some 16 devices, or so.
    An small FW hub (30$) makes things easier when you need to unplug the HDs.
    Rafael
    http://www.nagavideo.com
  • Michael Sacci
    January 17, 2010 at 5:43 am
    I think you can safely assume that he is talking about firewire drives, there are really the only type of drives that you are able to daisy chain.
    Ned,
    Personally as a practice I would never daisy chain drives and then if I had to I wouldn’t do more then one extra drive on a chain. If you need to have several drives attached at the same time, get a FW card with extra channels.
    For me the channel is to stay away from an edge as possible. I don’t want to see how close I can get to a problem. I want to stay away. With editing you are always accessing the drives, unlike basic computer work where you read and write to a drive every now and then, for them you can daisy chain away, for us it just is not a good practice.
    This is not a technical answer but my way of thinking.
