Activity Forums Apple Final Cut Pro Legacy Daisy Chained drives and FCP
  • Daisy Chained drives and FCP
    Posted by Seth Keal on May 22, 2009 at 5:20 pm
    I am working on a pretty large feature Documentary. I have 5 terabyte drives daisy chained together via firewire 800. I have imported my P2 Footage via mxf4mac. I have a Power Mac G5 dual 1.8 ghz with 4gigs of ram. I am running the latest FCP version. With that said here is the problem.
    If I have a sequence that has an hour of footage on it and I am trying to fastforward (3xL) sometimes the beachball will appear, stop the fast forwarding, then jump ahead without going through the rest of the footage. This is slowing me down and can get aggravating. I also just opened Title 3d and typed in something simple and pressed apply and it gave me an out of memory notice. I then checked the Activity Monitor to see if there was a tremedous amount of RAM being eaten up somewhere and there was 2.45 gigs not being used.
    So the ultimate question is; Is the Computer that I am running just too slow for what I am doing? I have the RAM maxed out so there’s nothing more I can do on that front. Would shocking PRAM help with this? Haven’t done it yet, but will try if it is necessary. Are the many drives daisy changed together causing the problem?
    I have worked with more drives than what I have daisy chained together now, in the past, but that was 720×480 SD. Now all my media now is DVCPROHD 720p 24pn. Is this causing the slow down?
    Any help would be greatly appreciated. Don’t want to have to get a new computer, but if that is what it takes to make my work flow actually work, then I need to make the investment, but I don’t want to buy a new computer and have the same problem. Thanks again for any help. cheers.
    Jason Levy replied 17 years, 3 months ago 7 Members · 8 Replies
  • 8 Replies
  • Michael Nease
    May 22, 2009 at 5:43 pm
    Hi Seth,
    It sounds like your hard drives might be spinning down when they’re not in use. What this means is that every time you reach a point in your timeline that needs to access footage from a different drive, if that drive hasn’t been used in a while it may have spun down and needs to spin back up in order to get to your footage. This might be the cause of your lag.
    If you haven’t done so already, go to System Preferences>Energy Saver and make sure “Put The Hard Disc(s) to sleep when possible” is not checked.
    If that’s the case, you might want to consider a larger shared storage option so you can keep all the footage essentially in one place.
    I hope this helps!
    Michael Nease
    Firebare Productions
    http://www.firebare.com
    Los Angeles, CA
  • Alan Okey
    May 22, 2009 at 6:35 pm
    You don’t need a new computer, you need media drives that don’t suck. That rules out Firewire drives, which are totally amateur hour. Take the plunge and get a real RAID:
    https://www.caldigit.com/HDElement/
    https://www.caldigit.com/HDOne/
    https://www.CalDigit.com/HDPro/
    Read this thread:
    https://forums.creativecow.net/thread/228/686
    Excerpt:
    The HD Element is a RAID 5 array package that is expandable, and is the CHEAPEST professional configuration on the market today. This means that no one has any excuse to not have a SAS/SATA RAID 5 configuration any longer for their professional editing or graphics workstation.
    -Bob Zelin
    I’m guessing that your current storage has no fault tolerance/redundancy, which means that if you lose a drive, you’re in a world of hurt – or at the very least, you’re in for a lot of recapturing.
    There’s no good excuse to rely on cheap external drives for video storage when there are great, affordable solutions that provide excellent performance and redundancy.
  • Seth Keal
    May 22, 2009 at 7:28 pm
    The drives I have now are duplicate drives from a gsafe housing and they are sata drives that are in Mercury Elite Pro casings, which have eSATA ports. I’m not in fear of losing anything, because I have an exact replica in storage of the drives and I haven’t digitized anything because I’m using MXF4mac.
    I have no way of plugging the eSATA cables in the computer and I don’t know if you can daisy chain these drives via eSATA. But I’ve read the benefit of using eSATA as opposed to firewire 800 is negligible.
    I haven’t really looked into what you have recommended, but can I pull my drives out of their casings and plug them into the HD element?
  • Alan Okey
    May 22, 2009 at 8:28 pm
    Regarding Firewire 800 vs. eSATA:
    https://www.barefeats.com/hard51.html
    Excerpt:
    “The main key to the speed advantage of Serial ATA is that each drive not only has a dedicated port but each port represents a dedicated data channel capable of 150 to 300MB/s, depending on the host adapter used.
    With FireWire 800, the drives are typically daisy changed on the same 100MB/s data channel. Even if you install a FireWire 800 PCI card with 4 ports, those four ports share the same 100MB/s data channel — as if they were daisy chained. It would take three PCI cards plus built-in FireWire 800 to equal four data channels.”
    As for the HDElement, it is shipped as a turnkey product. It must be purchased fully populated and does not support third party hard drives. However, you are assured of exhaustive QC testing and full warranty support from a single vendor in the event of any problems.
  • Richard Sanchez
    May 22, 2009 at 8:50 pm
    I would highly recommend an HD Element for your work. I work with DVCPRO HD and Pro Res very frequently, and the HD Element works like a champ. Also, Cal Digit has excellent customer support. The only thing is, I don’t know if they have a PCI-X version of their RAID card, which is necessary for the HD Element.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Jared Picune
    May 22, 2009 at 9:04 pm
    Unforturentrly the CalDigit RAID Card is only PCIe. The HDOne, HDPro, and CalDigit VR can all be used in PCI-x machines though.
    Jared Picune
    CalDigit. Serious Storage.Denver Final Cut Pro UG
    Geeky Mac | FCP Tips & Tricks
  • James Carter
    May 22, 2009 at 9:22 pm
    hmm interesting.
  • Jason Levy
    May 23, 2009 at 5:27 am
    One thing to remember is that just because your system has free memory does not mean that FCP is not running out of memory – there is a limit to how much it can use regardless of how many gigs you have installed. (2 gigs is it?)
    It’s important to make sure that your projects stay small. Everything in your project takes space – don’t have anything in there that you don’t need. If you have a lot of old versions of your sequences keep them in a secondary project. If there is stuff like stock shots or stock music that you can get right from the finder don’t keep it in the project.
    It does sound like your drives are too slow… but that doesn’t explain the out of memory problem.. your projects may be bloated too.. keep them slim if you can.
