Activity Forums DaVinci Resolve Da Vinci to Autodesk Flame
  • Da Vinci to Autodesk Flame
    Posted by Jobert Monteras on January 12, 2010 at 11:22 pm
    Hi! The company I work for uses Da Vinci Resolve for grading and lately we acquired an Autodesk Flame but we’re having problems conforming DPX files that comes out from the Resolve.
    The workflow is like this we get offline EDL’s from FCP and then we grade the R3D files in the Resolve and then export to DPX and do the online on the Flame. The problem is that the footages gets renamed when Da Vinci exports it. And because of this we can’t assemble the timeline in autodesk flame because the filename is so different form the offline. From an R3D footage that has an alphanumeric filename with more than 8 characters the Resolve changes it to an 8 character numeric filename. is there anyway for the resolve to retain the original filename? Because even if we choose to use fileheader timecode we still get the same problems on the flame.
    Thank you in advance. I’ll appreciate any help that you guys can give.
    Senior VFX Artist
    Roadrunner Networks Inc.
    https://www.roadrunner.com.ph/
    Jobert Monteras replied 16 years, 8 months ago 3 Members · 4 Replies
  • Ronald Anderson
    January 13, 2010 at 11:37 am
    I believe Black Magic is aware of this issue, and plan to address it soon. It’s a known problem…
  • Dwaine Maggart
    January 15, 2010 at 7:30 pm
    This would be the recommended solution:
    On the Render page, select “Use Prefix, Suffix, Number of Digits from Source” and Recording Mode, select “Source” should render the file similar to r3d naming convention.
    Also, feel free to send Resolve related operational questions to our support email group at:
    davincihelp@blackmagic-design.com
    Regards,
    Dwaine
  • Dwaine Maggart
    January 16, 2010 at 6:31 am
    It’s been brought to my attention that the response I posted was a bit confusing, so below I will try to clarify it.
    On the “Record” page (access with “Control r”), select the “Use Prefix, Suffix, Number of Digits from Source” check box, and on the “Recording Mode” drop down menu, select “Source”. This should render the file similar to r3d naming convention.
    In the version 6 operations guide, this is described on pages 265 through 269.
    If you don’t have the version 6 operations guide, you can download a PDF version here:
    https://www.blackmagic-design.com/downloads/davinci/pdf/DaVinciResolveManual.pdf
    Actually, what you will be downloading at that link is the very latest Resolve operations guide, with BMD branding and some updates from the original version 6 manual. So all current Resolve users should probably download this new operations manual. And in this manual, the Record page description is on pages 200 through 205.
    I hope this is helpful.
    Regards,
    Dwaine
  • Jobert Monteras
    January 16, 2010 at 5:47 pm
    Thanks Dwaine I got it! I was able to export the exact names as the R3D files. Thank you also Ronald for the response.
    Regards,
    Jobert
    Senior VFX Artist
