Activity Forums DaVinci Resolve Da Vinci freezes then crashes
  • Da Vinci freezes then crashes
    Posted by David Baudry on December 16, 2015 at 4:00 pm
    Hello I was working with a client on da vinci and the it started to freeze each time i press play.
    I changed in the pref cpu prices mode and it crashes.
    the project is a feature in HD.
    I don t know what to do.
    Config:
    latest Resolve 12.1
    latest cuda drivers
    Imac 27′ late 2013
    processor: 3,2ghz
    32go ram
    Nvidia GT 55M
    ultra studio mini monitor converting thunderbolt to ski then a FSI monitor
    wave panel
    Thanx a lot to anyone that could help, I would appreciate a lot the help from Da Vinci Team
    Joseph Owens replied 10 years, 8 months ago 2 Members · 1 Reply
  • Joseph Owens
    December 16, 2015 at 6:52 pm
    [David Baudry] “it started to freeze each time i press play”
    Normally I associate this behaviour with overloading the call for data from the source drive or exceeding the VRAM associated with the GPU. You appear to be running a single Graphics card, the iMac internal nVidia GT55M. Are you sure this is not the GT755M with 1 GB of VRAM? If so, this card would be seriously under-powered.
    You can correlate your system with the DaVinci Resolve on iMac configuration guide. The information mostly relevant to the late 2012 27″ iMac stresses a model with a minimum of 2GB of GPU memory and to make absolutely sure you are running in 64-bit kernel.
    If you are using a compressed codec, the CPU can also become seriously overloaded — even Apple ProRes presents a challenge for a single-GPU system, but RED or H264 would likely exceed the capability of an all-in-one computing platform.
    As far as the 2012 iMac is concerned, the official position of BMD is (quoting from the 2013 config guide):
    “…provides a flexible and simple desktop workhorse for real time previewing, grading and finishing material up to and including HD. It can also provide a good platform to review and grade higher resolution than HD images which you can render at slower than real time in the iMac. Alternatively use it as a grading station, then move the project to a faster hardware platform such as the MacPro for rendering.”
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
