Activity Forums Apple Final Cut Pro Legacy D88 -OMF files to final cut
  • D88 -OMF files to final cut
    Posted by Elcampeon77 on October 11, 2006 at 8:30 pm
    Hey I got about 4 hours of D88 tapes. They were already transferred to omfs but final cut does not reconize them what I need is these tapes put in to usable media. They are eight channels and I need the time code attached so I can sync it up with my cut. I heard automatic duck was my only way to get this done. I have a budget I just need to know what is the best method to get this done. And I need to find somebody to do it.
    thanks
    Jeff
    Meesta Joe replied 19 years, 10 months ago 4 Members · 6 Replies
  • Aaron Neitz
    October 11, 2006 at 9:48 pm
    Automatic duck will do it… it’s like $500.
  • Elcampeon77
    October 11, 2006 at 10:47 pm
    is there any thing eles does any one have this software out there?
  • John Pale
    October 12, 2006 at 1:02 am
    Book some time on an Avid.
    Import them into the Avid (OMF is their format), then export AIFF files to use in FCP
  • Elcampeon77
    October 12, 2006 at 1:51 am
    can we export those omf files with timecode in them? So I can sync them back to my cut.
  • John Pale
    October 12, 2006 at 8:54 am
    I just tested on an Avid, and the answer apparently is no. The timecode reverts to 1 hour straight up.
    I suppose if the timecode on the D88’s is continuous, you could simply note the start times, then modify the timecode to match after you import into FCP.
    Automatic Duck may be the only other solution.
    https://automaticduck.com/products/pifcp/
  • Meesta Joe
    October 13, 2006 at 3:37 pm
    Or import them into Pro Tools and export the AIFFs into FCP
    -AG
